Where's the *.* Horn?
Postby nifty » Fri May 21, 2010 2:08 pm
2000 Transit mini bus. Horn is not working. Fuse is ok. Looked for horn to check wiring - can't find it! Feel really stupid. :?
BTW, thanks for all the help with my last problem - power drain on Transit. Put a new alternator in and it's working fine. Gassed up the air-con. and the compressor works fine. Saved $2500 that Ford was going to charge!
nifty
Re: Where's the *.* Horn?
Postby MrMPuk » Fri May 21, 2010 2:12 pm
Under the right hand headlight behind the grille\bumper.
Postby Timbo » Fri May 21, 2010 7:33 pm
Under LEFT hand headlight (from driver's seat) if Mk5.
Timbo
Postby captain hook » Sat May 22, 2010 12:13 am
Under Left Headlight on my MK6 8)
captain hook
Postby MrMPuk » Sat May 22, 2010 12:36 am
Timbo wrote:Under LEFT hand headlight (from driver's seat) if Mk5.
I was talking from looking at the front, was gonna say near side but don't think this dude is in this country although his local doesn't say.
captain hook wrote:Under Left Headlight on my MK6 8)
Tis a Mk5.
Postby nifty » Sat May 22, 2010 8:37 am
Anyone want to try for under the tow-bar? :D
Had a tour in it to-day so I'll check (both sides) in the morning. Thanks guys, helpful as always. PS I'm in Australia.
nifty
Postby nifty » Sun May 23, 2010 3:01 am
Found it :D Do you think if they tried really hard they could find somewhere more awkward to put it :?: Problem is, the wires look ok, the fuse is ok (same fuse for hazards) it just doesn't work. Unless the horn itself is u/s it could be the connections off the stalk (same stalk as the indicators). Any thoughts gentlemen :?:
nifty
Postby sc_BK » Sun May 23, 2010 11:45 am
Have you got 12v at the horn?
sc_BK
