by Ked » Mon May 24, 2010 9:15 pm
Check around the water pump gasket and any water pipes for white looking powerdery stuff.
If it is leaking from a gasket, a temp fix is to silicone iaround the seal in leiu of a replacement gasket. Wudn't recommend taking it apart cus u will have to bleed system. In my car this involved running the aircon whilst revving the engine some till the aircon was cold, although this is a vague memory. More was involved I am sure.
