Rear axle tag
Rear axle tag
Postby Wildy » Thu Jun 17, 2010 11:16 am
Does the tag on a mk5 5 stud axle show the diff ratio? I've looked at an axle today but the tag only appears to have the part number stamped down the middle. Can the ratio be identified from this? Unlike the 6 stud axles which have the info on the tag.
Some people are like slinkies, not really good for anything
but they bring a smile to your face when pushed down the stairs.
Wildy
Re: Rear axle tag
Postby MrMPuk » Thu Jun 17, 2010 11:30 am
What were the numbers on the tag?
Re: Rear axle tag
Postby Wildy » Thu Jun 17, 2010 3:11 pm
It was difficult to make out, but after a little wire brushing im sure about seven or eight digits in there was 411?
Wildy
Re: Rear axle tag
Postby MinorMatt » Thu Jun 17, 2010 6:59 pm
it should be in big letters like the 6 stud ones
did you remove the tag from the scrappy and bring it back to read it clearer ;)
Re: Rear axle tag
Postby Wildy » Thu Jun 17, 2010 8:59 pm
MinorMatt wrote:it should be in big letters like the 6 stud ones
No,I could see enough to know it wasn't the same as the 6 stud tags. It only had a line of digits down the middle. I may investigate further :wink:
Wildy
Re: Rear axle tag
Postby MinorMatt » Thu Jun 17, 2010 10:52 pm
well if you get the complete number someone might put it in to microcat for you ;)
Re: Rear axle tag
Postby MrMPuk » Thu Jun 17, 2010 10:53 pm
I believe you can tell from the number, no need for microcat.
