Hello every one
I have a swb smiley transit diesel i do alot of mileage between England and Ireland but the diesel is currently alot cheaper in Ireland (and euro alot weaker /customs wont let you carry drums/gerry cans through the ports)my question is has anyone fitted a 2nd tank on the RHS of smiley shape before plan is to cut in 2nd filler neck in b pillar and use filler pipe from LHS but exhaust runs along LHS as well which makes a normal smiley tank impossable just wondering can anyone think of a tank that might be the correct size or would i be able to get one fabricated (would like to be able to fit a transit sender unit so i can wire into orignal gauge on 2way switch) then using a electric fuel pump transfer the fuel from 2nd tank into orignal tank when it starts to run low any ideas appreciated Mick
