Cannot engage gears
Cannot engage gears
Postby Bago » Tue Jul 13, 2010 10:14 pm
Hello,
I have a SWB low top 150 Custom Mk5 Smiley and the clutch biting point is suddenly 'on the floor' and I can't select any gears. The only way I can drive it, is to turn the engine off, select a gear and start it up, then I'm stuck in the gear I have chosen.
Is it clutch or gearbox, any ideas would be most appreciated.
Ian
Mark 5 Smiley 150S (3.2 ton) Turbo SWB low roof Custom with BullBars, hotscreen, rpm counter, power windows, power mirrors, tailgate, cd, ABS brakes, captains chair, cup holder and near mint cond.
Bago
Re: Cannot engage gears
Postby Grenadekid » Tue Jul 13, 2010 10:16 pm
could be a stretched clutch cable about to snap
At home
05 220 tdci connect (remapped to 115)
94 toyota rav4 2.0 petrol
2011 kia sportage kx3 2.0 diesel
2001 RAV4 NG
Grenadekid
Postby Bago » Tue Jul 13, 2010 10:28 pm
Hopefully thats all it is and not gearbox probs.
Bago
Postby the_big_fact_hunt » Wed Jul 14, 2010 12:00 am
has it got a ratchet at the top of the pedal? could just need resetting
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby jay » Wed Jul 14, 2010 7:54 am
will be manual adjuster on a mk5 on the end of the clutch pedal there is a 10mm nut might be a idea to just check this hasnt come undone even though it should be a nylock nut...
mk1 connect tourneo
jay
Postby Bago » Wed Jul 14, 2010 9:25 am
Thanks mate, I tightened the nut and now I can get all gears. However, first is really stiff and notchy to engage, but now and again it goes in smoothly. Not very often though. Most times its a fight to get first gear. Any more ideas?
Thanks very much for your time.
Ian
Bago
Postby the_big_fact_hunt » Wed Jul 14, 2010 6:44 pm
select 2nd then first, its usually easier, my old van was like that
2012 115T350
the_big_fact_hunt
Postby Grenadekid » Wed Jul 14, 2010 7:45 pm
If you tightened it and now you are getting gears its probably the cable, you should change it before it snaps all together. Hopefully its not the pressure plate on the way out but they are not too hard to change although adds more expense you will know once you,ve got the new cable in
At home
2001 RAV4 NG
Grenadekid
Postby Ollie » Thu Jul 15, 2010 3:53 pm
Did one last week where the operating arm inside the bellhousing had broken and was bending? might be worth a look in the side with a torch
Ollie
Ollie
Postby Bago » Fri Jul 16, 2010 4:35 pm
Thanks Guys,
It was indeed the operating arm Ollie. It was also the nose cone on the gearbox I'm told and selectors. We've changed the operating arm, clutch and still it was dodgy going into first. I managed to get a 63,000 mile box from a scrapper and flushed and changed all the fluids and it's as slick as can be now!
Ian
Bago
