MK2 Alternator
MK2 Alternator
Postby badger » Wed Jun 22, 2005 10:13 pm
Hello all,
I have just found your site and found it very useful. I have a 1982 MK2, which I am currently restoring as a campervan.
I hope someone can offer me some advice. The alternator has gone and I have been looking for a cheap replacement, does anyone know what other ford alternator will fit as I was going to see what they had on ebay.
Hope some one can help.
Toby
badger
Postby FredTransit » Wed Jun 22, 2005 10:20 pm
Hi badger, welcome. I don't think alternators are too expensive (petrol or diesel BTW?), try your local motor factors or scrappie. If you buy a 2nd hand one, make sure the light isn't on, even faintly, when the engine is running (make sure the heater fan is off). If it is and gets dimmer when you switch someting on GET IT CHECKED. At best this can cook the battery, at worst cause a wiring fire that could take the whole van with it. The wireing loom passed over the air filter, and if the air cleaner catches you are in trouble. It's a common fault with the Mk2, from day 1.
FredTransit
Mk2 Trannyist
Postby bortaf » Wed Jun 22, 2005 11:02 pm
If it's a pinto (petrol) you can use a cortina,capri,or Mk2 granada alternator as long as it's a pinto engine it will fit.
If you get one from a granada or sierra the wiring will need altering as they are bolt on wires not the plug type but as a bonus if it's from a Ghia it'll be a higher powerd unit ideal if you have twin batterys :D .
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby simgy » Thu Jun 23, 2005 10:24 am
think mine came off a rover
simgy
Postby Luke » Thu Jun 23, 2005 10:29 am
Welcome badger :D
I fitted a sierra injection one to a Di (if thats what your engine is :? ) needed to mod the tension braket but its a higher output alt than normal!!!
:D
Postby mk2panelvan » Thu Jun 23, 2005 12:01 pm
Welcome badger ..............see how great the info is on here..........oooooo you have a Mk2 I'm green with envy!!! :D :D :lol: :lol: :D :D
If at first you don't succeed, remove all evidence you ever tried
http://uk.geocities.com/thenandnowkillingbeck/
mk2panelvan
Postby badger » Thu Jun 23, 2005 9:08 pm
Thanks for the advice guys, abig help. Have ordered an alternator.
badger
