Diesel auto question
Postby AndyJ2506 » Tue Sep 28, 2010 10:08 pm
Is it possible to fit an auto box to a mk5 diesel engine, and if yes does anyone know how much work would be involved
Ta
Call 07739463511
AndyJ2506
Re: Diesel auto question
Postby jay » Tue Sep 28, 2010 10:22 pm
yes but you need a early auto box that hasnt got the electric bits on it.As later boxes are controlled by the engine ecu. sometimes easier to just change the van or buy a compleate van and change over loom and engine and box..
mk1 connect tourneo
jay
Postby AndyJ2506 » Tue Sep 28, 2010 10:25 pm
Cheers for the reply
did they even make a mk5 diesel auto as i was wondering as well about adaptor plate etc
Call 07739463511
AndyJ2506
Postby AndyG » Tue Sep 28, 2010 11:01 pm
Have you not seen my van :?: (North Weald :wink: )
Parked to the right of you here :lol:
Postby AndyJ2506 » Tue Sep 28, 2010 11:09 pm
Yup but I didn't realise it was auto :lol: did you convert it and if so how much hastle was it and what is needed please
Call 07739463511
AndyJ2506
Postby MrMPuk » Tue Sep 28, 2010 11:10 pm
AndyJ2506 wrote:Yup but I didn't realise it was auto :lol: did you convert it and if so how much hastle was it and what is needed please
No it's factory turbo diesel auto.
Postby AndyJ2506 » Tue Sep 28, 2010 11:13 pm
Ah that answers one question then
Call 07739463511
AndyJ2506
Postby AndyG » Tue Sep 28, 2010 11:24 pm
To convert yours correctly (which has a Bosch manual pump) you really need a MK4 Di auto donor :!:
Parts req;
Diesel autobox
Converter
Flywheel
Cross member support for the autobox and rear "engine" mount
Prop shaft
Selector assy
Pierburg valve
Pipes for Pierburg valve
Kickdown cable
Speedometer cable
A bit of wiring for the inhibit/reverse light switch
Oh and a BIG oil cooler (and pipes) :wink:
Is what comes to mind at the moment :!: :lol:
Postby AndyJ2506 » Wed Sep 29, 2010 7:48 pm
Cheers Andy. sounds complicated i think this one will have to go on the back burner for a while :( I will keep my eyes peeled for a donor vehicle tho
Call 07739463511
AndyJ2506
Postby frankwilliams » Wed Sep 29, 2010 8:14 pm
They did make the mk5 in diesel with the autobox.
I'm just bought a complete van(turbodiesel) and completly took it appart. :D
This will be the new drivline for my mk2!! :mrgreen:
See also my topic in the mk1&mk2 section.
viewtopic.php?f=3&t=73107
With kind regards,
FrankWilliams
frankwilliams
Postby AndyJ2506 » Wed Sep 29, 2010 8:19 pm
very nice but now i'm jealous :lol:
Call 07739463511
AndyJ2506
Postby frankwilliams » Wed Sep 29, 2010 8:24 pm
Sorry.........
But, don't be jealous, the mk5 was a LHD anyways (i'm from the Netherlands), and as the driveline is nearly new (literally) the rest of the van had loads of rust!!
So no MOT anymore, a very fine example to use as donor vehicle to realy update my mk2.
FrankWilliams
frankwilliams
Postby jay » Wed Sep 29, 2010 8:59 pm
@frank you used the engine and loom though..OP was asking to use his engine and fit that box you have..your box wont work properly without the ecu as the engine talks to the gearbox through the ecu and box will change as needed...
mk1 connect tourneo
jay
Postby AndyJ2506 » Wed Sep 29, 2010 9:53 pm
Cheers I think I'll look at other options now
Call 07739463511
AndyJ2506
