ford transit headlamps..very dull light
Postby grdnrdave » Mon Oct 04, 2010 11:32 pm
HI . I HAVE A MK6 TRANSIT AND SINCE I HAVE OWNED IT , THE DIP/FULL BEAM DOESNT SEEM TO BE VERY BRIGHT , IN FACT ITS SO DULL I HAVE TO HAVE FULL BEAM ON AND MY HEADLAMPS SET TO 4 ON THE SWITCH TO BE ABLE TO SEE , THE DIP IS WORSE THAN A CANDLE , ANY ADVICE GRATEFULLY RECIEVED,
grdnrdave
Re: ford transit headlamps..very dull light
Postby dan83590 » Tue Oct 05, 2010 10:42 pm
Unless fully loaded it shoulg be set at 0 (zero).
Could be as simple as crappy bulbs. Could be wiring. Could be dirty lenses. etc.
Cheap bulbs are SH!TE...
dan83590
Postby grdnrdave » Wed Oct 06, 2010 5:06 pm
lenses are fine ,bulbs are brand new , maybe wiring , i will check it out , had them on 4 so i could use main beam as dip , cheers for the help bud
grdnrdave
Postby AlanN » Wed Oct 06, 2010 5:17 pm
Don't know much about MK6's, but check the earths and connections to bulbs as they sit in a fibreglass panel. Even add a temporary earth, then go to lighting switch and check connection there
Postby MrMPuk » Wed Oct 06, 2010 5:19 pm
dan83590 wrote:Unless fully loaded it shoulg be set at 0 (zero).
But if he did that with the full beam on he'd blind oncoming drivers.
Postby dan83590 » Wed Oct 06, 2010 6:19 pm
Sounds like the circuit could be at fault then. A bad earth, or a damged wire earthing onto something it shouldn't be touching?? It could be easier to just replace the wire(s) rather than find the fault.
dan83590
