Laden brake valve
Laden brake valve
Postby southfield » Thu Dec 16, 2010 3:38 pm
When fitting a new laden brake valve is there any special position this has to be fitted in?
I have a Y reg 350 LWB
southfield
Re: Laden brake valve
Postby Frag » Thu Dec 16, 2010 9:23 pm
The length of the rod is the critical factor,seem to think there is a sticker somewhere with info on it :?
(in the cab ?/step or behind seat,never needed it but sure i`ve seen one ????)
I`ve set them before but we had a plastic clip that fitted on top end of rod,pre-loading it,then you just adjusted the moving slider to take play out of rod.
Really rod would need setting with vehicle unloaded/empty.
If youre just changing the valve,mark the rod position first. :idea:
Frag
Ford Technician
