Mines '99, manifold to downpipes, the trangular 3 hole type, is the 2 sizes of this gasket, ie the std one and the turbo is a bigger one, the reason I ask is that I got a couple off t'ebay and neither of them were right, the one at the manifold was way so much bigget and the one at the bottom (downpipe to boxes) was slightly smaller central hole, plus the bolts hole wouldn't accept the tranny's 10mm bolts (had already got the right one for the manifold locally, but had to use the old one at the bottom), bloke on ebay listed it for my engine/year but say's I've ordered the wrong one and there's several that fit transit (talking about the tri oval one)...
Incidentally laziness is costly, the tri gasket worked out just under 6 quid.... it was £1.30 at the shop
