engine not stopping!
Postby iain » Tue Jul 19, 2005 9:44 pm
hello,bought a 99t reg transit ,has fault with ignition ? switch of ignition and engine does not always stop can even remove the key usually giving a bit throttle the engine cuts out ,one time it did not start ,advised to lock doors and and try again and it did start .have had new keys made by ford dealer and garage that sold van also replaced the unit on steering wheel expecting the contacts to be sticking but tonight it has been very reluctant to stop ! had to stall any ideas of where problem lies much appreciated
iain
Postby FredTransit » Tue Jul 19, 2005 9:50 pm
Welcome Iain, can't help with your problem as my knowledge stops at around 1988!! I am sure somebody on here will though. :D
FredTransit
Mk2 Trannyist
Postby MrMPuk » Tue Jul 19, 2005 9:53 pm
I would say it's probably got something to do with the stop/run solenoid which is within the fuel pump, so I would take it to a diesel fuel pump specialist and they will probably have it sorted in no time at all!
Postby MrMPuk » Tue Jul 19, 2005 9:54 pm
That is of course if it's a diesel!!! :D
Postby transitgeoff » Tue Jul 19, 2005 10:01 pm
Hi the fuelpump is breaking up inside and the metal fillings produced gather around the stop solonoid as its magnetic thus jaming the solonoid and causing the vehicle not to switch off correctly, when replacing the pump be sure to clean the whole fuel system tank and all as diesels circulate the fuel so metal fillings will be all round the system and will contaminate the new pump :D
transitgeoff
Postby MrMPuk » Tue Jul 19, 2005 10:05 pm
Yeah was thinking that Geoff but didn't want to put a downer on the new van, but you're probably right!
Postby iain » Tue Jul 19, 2005 10:09 pm
thanks to you all for helpful replies will get pump checked/replaced
iain
Postby FredTransit » Tue Jul 19, 2005 10:10 pm
..........must be a diesel then :D
FredTransit
Mk2 Trannyist
Postby MrMPuk » Tue Jul 19, 2005 10:18 pm
Guess so Fred
Postby iain » Tue Jul 19, 2005 10:33 pm
yes diesel and bits of metal.another thought i am in scottish borders and going to rye on the south coast at weekend and time for getting pump checked is limited is it likely at some point engine will refuse to start .thanks
iain
Postby transitgeoff » Tue Jul 19, 2005 10:42 pm
get it sorted a.s.a.p, no-one knows how long it will last :roll:
transitgeoff
Postby iain » Tue Jul 19, 2005 10:46 pm
thanks again will be on phone in morning to arrange
iain
Postby iain » Fri Jul 29, 2005 7:31 pm
thanks to mrmpuk and transitgeoff, with your advice took van back to garage last thursday pump was checked and replaced :D
iain
