john leeman wrote:some swb rear axles do whine after a high milage, check for back lash from the prop to diff flange, ie turn the prop with your hand, with hand brake on. if the movement is quite a lot, the diff maybe worn out, you could put some wynn's diff oil additve, may have been run with low oil level in diff ?. the other thing it could be is propshaft centre bearing, get a friend to sit in the back and listen to the floor to determin where the noise is coming from. good luck.
