mk1 di
Postby Gunslinger » Wed Aug 31, 2005 10:28 am
ah crap, i'm always getting peoples locations wrong, sorry about that :oops:
Gunslinger
Postby Luke » Wed Aug 31, 2005 8:23 pm
ovlov wrote::shock: What clutch cable did you use Luke :lol:
spoke to Bob he has jogged my memory!! :lol:
What i did was weld a bolt (with the head cut off) on to the end of the existing clutch cable :? sounds a bodge but it wasnt - if you get a decent weld on it wll be stronger than the crimped on end!! it will need grinding flush to fit through the hole i think it was an M8 bolt mabe 100mm or longer!!!
then i used 2 locking nuts to take up the adjustment!!!
4 years later its still going so cant be bad!!! :D
