mk3 front new leaf hanger too far back
Postby Twin Wheel Burning » Thu Jun 28, 2012 9:03 pm
Hi there, I have a 1991 twin wheel Mk 3 and I have had the front cross member and front leaf spring hangers replaced. Problem is, the front rear leaf spring hanger is pushed right back, the bump stop is out of line and the front end is bottoming out because I now have no "spring" in the front leafs :roll: . I took it to my mate who did the work and he says that the new cross member and leaf spring hangers were put back the way they came off. It's not an option to cut the hangers back out e.t.c but I wonder if there is another way to put the problem right. I'm thinking a leaf spring 1 inch shorter would fix the problem but I don't know if this is a possibility or where I would get one. What I really want to know is if anyone has had the same issue and is there a way round this. Iv'e had my van for years now and I am very attached!! So, I would really appreciate anyone's advice.
Thanks in advance!! :D
Twin Wheel Burning
Re: mk3 front new leaf hanger too far back
Postby Ken B » Fri Jun 29, 2012 11:23 am
If you made a spring 1" shorter its very unlikely to have the same spring rate as the longer one. I think your mate "owes" you to put it right, as he clearly hasn't. Assuming it wasn't like this before. I'm guessing he hasn't welded everything back correctly. But some photos would help. I'm also guessing if your spring is postioned further back than the other one, your axle must be trying to turn the van constantly in one direction or the other?
Ken B
Location: Spalding lincs. The land that time has forgotton.
Postby jay » Fri Jun 29, 2012 1:11 pm
sounds like the spring mount wasnt welding in the right place..
mk1 connect tourneo
jay
Postby Highlander250469 » Fri Jun 29, 2012 1:14 pm
Ken B wrote:If you made a spring 1" shorter its very unlikely to have the same spring rate as the longer one. I think your mate "owes" you to put it right, as he clearly hasn't. Assuming it wasn't like this before. I'm guessing he hasn't welded everything back correctly. But some photos would help. I'm also guessing if your spring is postioned further back than the other one, your axle must be trying to turn the van constantly in one direction or the other?
both springs and hangers are the same he said.
Does sound like they've been put on in the wrong place or you'd have noticed these same symptoms before they were done surely?
just to clarify, the front crossmember and front hangers were replaced, so the rear hangers are still in the same place as before?
Front hangers must have been put on too far forward then?
Highlander250469
Postby Ken B » Fri Jun 29, 2012 1:59 pm
Yea sorry I originally read it as one side being done not the other.
I think he means the rear shackles not hangers are pushed right back, so would that not mean the front are welded too far back?
Ken B
Postby Twin Wheel Burning » Fri Jun 29, 2012 5:29 pm
Yeh that's right sorry the rear shackles are pushed back over because the cross member and hangers seem to be welded on about an inch too far back. The lad that did the work for me seems to think there was no other way of welding them on wrong and said it may be because they are copy parts. Sometimes wish I could convert to coil springs for less hassle :lol:
Thanks for helping!!
I'll put some photo's on now
Twin Wheel Burning
Postby Twin Wheel Burning » Fri Jun 29, 2012 6:38 pm
Twin Wheel Burning wrote:Yeh that's right sorry the rear shackles are pushed back over because the cross member and hangers seem to be welded on about an inch too far back. The lad that did the work for me seems to think there was no other way of welding them on wrong and said it may be because they are copy parts. Sometimes wish I could convert to coil springs for less hassle :lol:
really struggling to upload a photo
Twin Wheel Burning
Postby jay » Fri Jun 29, 2012 9:04 pm
viewtopic.php?t=23
A how to add pics on the link above may help
mk1 connect tourneo
jay
Postby Twin Wheel Burning » Fri Jun 29, 2012 9:51 pm
[quote="Twin Wheel Burning"][quote="Twin Wheel Burning"]Yeh that's right sorry the rear shackles are pushed back over because the cross member and hangers seem to be welded on about an inch too far back. The lad that did the work for me seems to think there was no other way of welding them on wrong and said it may be because they are copy parts. Sometimes wish I could convert to coil springs for less hassle :lol:
Last edited by Twin Wheel Burning on Fri Jun 29, 2012 10:03 pm, edited 2 times in total.
Twin Wheel Burning
Postby jay » Fri Jun 29, 2012 9:53 pm
have u a pic of the front hangers?
mk1 connect tourneo
jay
Postby Twin Wheel Burning » Fri Jun 29, 2012 10:05 pm
that is a great help so thanks for the advice on getting photos on here. I will work on getting them to the right size now :lol:
I'll put a pic of the front ones up now m8
Twin Wheel Burning
Postby robbie.cee » Fri Jun 29, 2012 10:12 pm
silly question but are they tthe right springs? are they identical length to originals??
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Twin Wheel Burning » Fri Jun 29, 2012 10:17 pm
front hangers... the left is the same
Twin Wheel Burning
Postby robbie.cee » Fri Jun 29, 2012 10:19 pm
oops he may have used the wrong holes? look left of the end of leaf... see another pair of holes?
guys???
Had
MAKE IT FIT
robbie.cee
Postby Twin Wheel Burning » Fri Jun 29, 2012 10:22 pm
robbie.cee wrote:silly question but are they tthe right springs? are they identical length to originals??
Yeh the springs were not replaced, just the front hangers and cross member. They were fine before the new metal was welded in.
Twin Wheel Burning
