davyjcb wrote:It's Euro 5 so it won't have conventional scv/prv as was on Euro 4
2 things I would be checking ,turn on ign until lit but don't try cranking then either listen for the pump in the tank or depress the shrader valve fitted in the fuel line between the filterhead and the high pressure pump to see if the low pressure pump in the tank is supplying fuel as the euro5 hp pump needs a certain amount of pressure in order to work.
karl wrote:they dont have a full cut off
bambi mk 1 wrote:karl wrote:they dont have a full cut off
You need an update on IDS ,euro 5 have an inertia switch in the glovebox,another school day eh
karl wrote:bambi mk 1 wrote:karl wrote:they dont have a full cut off
another school day as always with you![]()
i have never seen a fuel cut of in a glove box of the one i maintain
am sure a picture may be help meeeh
