Mk4/5 single to twin fitment. Anchor point and bolts
Postby Manchestermatt1986 » Tue Apr 19, 2022 11:16 am
2000 mk4 single to twin.
I'm in the middle of swapping the seats. The single had 4 x bolts into the runners. And the runners had 7 x bolts for the runners. 6 x being rhe runners and a 7th for the seatbelt.
The twin has a anchor catch but what does it catch too?
Also the bolts are 4 x at the front which appear that 1x each side has no hole drilled for it
Can someone please advise
Last edited by Manchestermatt1986 on Tue Apr 19, 2022 11:57 am, edited 1 time in total.
Manchestermatt1986
Re: Mk4 single to twin fitment. Anchor point and bolts
Postby dumper » Tue Apr 19, 2022 11:38 am
Have a look underneath you may find some captive nuts welded to the bottom of the floor on my mk3 they had no threads in them and no hole in the floor what I did was drill up from underneath with a drill that didn’t take any metal out of the nut and drill though the floor I then got a tapered tap and tapped it out from the top for the bolts I was using.
Not sure but I think when Ford fitted the seat they used a self tapping bolt looking at the flutes in the bolts I removed that’s possible why the nuts are not threaded.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Manchestermatt1986 » Tue Apr 19, 2022 11:56 am
It looks like a latch plate/striker is missing?
Manchestermatt1986
Re: Mk4/5 single to twin fitment. Anchor point and bolts
Postby MinorMatt » Tue Apr 19, 2022 12:06 pm
Thats because the latch is missing...
Transit seats tipped up to 1997, and after that didn't. There is a "loop" plate that bolts to the floor which you are missing.
Ford used self tapping bolts in all of the holes - so any which have not previously been used will not be threaded, either use tapping bolts and an impact gun, or run a tap down the the threads
Postby Manchestermatt1986 » Tue Apr 19, 2022 12:38 pm
Do you have or know where I can get the loop plate?
Manchestermatt1986
Postby MinorMatt » Tue Apr 19, 2022 3:46 pm
If you google image search "6762879 Transit" you can see one with lots of images what it looks like (mk4 version)
Postby Manchestermatt1986 » Tue Apr 19, 2022 9:44 pm
I've checked it out thankyou. The pictures are of parts for sale in the Ukraine, if you've got one for sale please let me know. Thanks for the replys
Manchestermatt1986
Postby Chug » Tue Apr 19, 2022 11:01 pm
I think these from mk8/custom could be made to work.
https://www.ebay.com/itm/FORD-TRANSIT-M ... 4594711682
Chug
Postby Manchestermatt1986 » Wed Apr 20, 2022 8:45 pm
I'll try and source one then if all else fails I'll look into making one fit
I hope your going to save my bacon Matt because I'm struggling to get one of these loop catchs. I've managed to get the part number but I've tried multiple sites and breakers with no result
I will have my wife and 1year old in the front so I really don't want to get into fabricating if I can help kt
Manchestermatt1986
Postby Keef » Wed Apr 20, 2022 9:58 pm
If your van is a 2000 like you say in your first post then it's a Mk5 so why don't you just buy a Mk5 non tilting seat and bolt it in?
You can then sell the Mk4 seat.
Keef
Postby knobby1 » Thu Apr 21, 2022 2:30 am
Keef wrote:If your van is a 2000 like you say in your first post then it's a Mk5 so why don't you just buy a Mk5 non tilting seat and bolt it in?
Mk6 started at the beginning of 2000. Mk5 was produced up until the end of August 2000....So a 2000 model can be either Mk5 or Mk6.
Mk4 ceased production in August of 1994.
Postby MinorMatt » Thu Apr 21, 2022 11:22 am
Manchestermatt1986 wrote:I'll try and source one then if all else fails I'll look into making one fit
I'm struggling- but still looking
Postby Manchestermatt1986 » Thu Apr 21, 2022 1:51 pm
If I can find a set that's a straight fit I'd prefer that. I'm looking online and again I can't see exactly if the bottom centre rear part will bolt straight in. I don't want 2 x seats I'm struggling to fit haha
Manchestermatt1986
Postby Manchestermatt1986 » Thu Apr 21, 2022 1:58 pm
For example, I can't see this fitting from on ebay
Manchestermatt1986
Postby MinorMatt » Mon Apr 25, 2022 8:57 am
That ebay one is a mk6 seat...
