by metalworker0 » Sat Jun 27, 2026 6:41 pm
the other sensor is in the evaporator core inside the dash .. temperature sensor that is
i don't know if forscan will read it .. worth a try
if it does the pids will be EVAP, EVAP_TMP, or EVAPORATOR_TEMP
minus -40 means it's failed
May have a pid for commanded and actual .. if so,. they will be the ones to take note of, make more sense
Now then>
I've looked at plenty of fixing vids on this and sometime the evaporator core sensor only available with the core !
ebay
ford transit custom evaporator
from the results (not sure what i'm seeing ) looks like it comes attached to that or is that just the expansion valve ?
catcar.info - no good as i don't know what im looking at really ... cant see a sensor there
don't go buying this .. test it
Note: some customs, ecoblues, have a system on them that has an electric pump at the side of the engine that pumps coolant around the ac heater when in stop start mode, so you get heat even if engine stopped .. if this system is fitted, ive no idea on how it effects the AC system. reports here , some of these pumps have failed in the permanently on mode .. that would screw things up
for what its worth .. take note AI can be wrong .. google ai answer to the question:
Does the transit custom have heat sensor in the evaporator core
Yes, the Ford Transit Custom (and the wider Ford Transit family) is equipped with an evaporator Function of the SensorPrevents Freezing: The sensor monitors the temperature of the air leaving the evaporator core .Controls the Compressor: If the temperature drops too close to freezing (which causes the condensation on the core to freeze and block airflow), the sensor signals the Powertrain Control Module (PCM) to disengage the AC compressor clutch .Diagnostics: A faulty or erratic sensor can result in the AC failing to turn on, blowing intermittently, or shutting off entirely.
metalworker0 on Sat Jun 27, 2026 6:55 pm, edited 3 times in total.
