won't run after fitting solid flywheel
Postby tipp3r » Fri Dec 25, 2009 1:39 pm
my transit starts of the key runs for about 4 secs and then just cuts out ,,,,2400 lwb transit 2001 model thanku
tipp3r
Re: want run
Postby MrMPuk » Fri Dec 25, 2009 6:07 pm
Easier if you reply to your original thread.
viewtopic.php?f=2&t=58045
Re: want run
Postby psv-hgv-flt » Fri Dec 25, 2009 8:33 pm
you need to get fault codes read. (plug in to ecu) :wink:
psv-hgv-flt
Re: want run
Postby tipp3r » Fri Dec 25, 2009 11:26 pm
i ran perfect tilli did cluctch ,,
tipp3r
Re: want run
Postby APH » Fri Dec 25, 2009 11:45 pm
Sounds like faulty / dirty crank sensor, did you disturb the carrier the sensor is inserted through, as re aligning is tricky. If not, and unless anyone can suggest anything else, i'd try a straight replacement.
(\__/)
(")_(")
this is bunny
APH
Re: want run
Postby tipp3r » Fri Dec 25, 2009 11:47 pm
weres the carrier is it easy to get the sensor out ,, cheers m8t
tipp3r
Re: want run
Postby APH » Sat Dec 26, 2009 12:03 am
Assuming you didn't remove the sensor if you don't know how it comes out, so carrier shouldnt be an issue, you should know where it is, as the sensor goes through the top of the bellhousing, directly over the flywheel, can be got to from under the vehical fairly easily, one multiplug to remove and one bolt. Give it a sharp pull upwards and it should come out (if top plug part breaks off like mine did, then grips, with a slight twisting motion will help)
Heres a pic of sensor if it helps you to identify the right one:
(\__/)
(")_(")
this is bunny
APH
Re: want run
Postby tipp3r » Sat Dec 26, 2009 12:07 am
cheers will try and clean it first thing in the morning are they ford only ,,
tipp3r
Re: want run
Postby APH » Sat Dec 26, 2009 12:21 am
Personally would only get from a dealers as its a major engine component (failure at any time will cause engine to cut out) although cheaper ones can be found on ebay, if you trust their reliability. Check the slightly magnetic tip of the sensor hasn't picked up a load of metal swarf from failing flywheel / clutch components though before replacing it.
Another thought, as it senses a missing pulse from a ring on the flywheel, is your new solid flywheel a genuine ford replacement for the dual mass. I know its woodruffed on to the crankshaft so it should be aligned ok, but if not the right one (or a bad copy) the sensor signal could be wrong or even non existant (giving incorrect engine timing).
Also when it cuts out, does the glowplug light flash?
(\__/)
(")_(")
this is bunny
APH
Re: want run
Postby tipp3r » Sat Dec 26, 2009 12:28 am
yeah i think the light does flash ,, yeah i changed the flywheel to a solid i hope its just the sensor ,,,,
tipp3r
Re: want run
Postby tipp3r » Sat Dec 26, 2009 12:32 am
was not geninue ford just a patern part ,, the bloke in the shop said hes never had a problem with them ,,,, you got me thinking now ,,,uesd to start perfect even when cluct was gohn ,
tipp3r
Re: want run
Postby APH » Sat Dec 26, 2009 12:43 am
Hmm... dont know how you check that one! i susspect as light flashes, if you got codes read, then crank sensor would show up, but it may not be the sesnor at fault if the flywheel isn't giving it a signal.
Replacing the sensor may solve it, but if flywheel is the issue, then obviously it wont and as sensor is about £40 from dealers, it could be a waste of good money.....
Will have to see if anyone else can suggest a possible solution, as this is now a catch 22 situation!!
Otherwise, although tis a lot of work, you could put the old flywheel back on without toucing the sensor (clutch being gone not an issue here) just to test it. If its starts ok again, then the flywheel is your problem.
Best of luck and keep us posted..
regards,
Andy.
(\__/)
(")_(")
this is bunny
APH
Re: want run
Postby tipp3r » Sat Dec 26, 2009 12:46 am
cheers any way will try and clean sensor firsts thanx
tipp3r
Re: want run
Postby APH » Sat Dec 26, 2009 12:55 am
Give it a go, wont do any harm (provided you dont break it getting it out) :wink:
(\__/)
(")_(")
this is bunny
APH
Re: won't run after fitting solid flywheel
Postby tipp3r » Sat Dec 26, 2009 12:14 pm
just took sensor out cleaned it put it back still the same ticks over for about 5 secs .....any ideas does the spedo wire have to connect to make it run cheeers
tipp3r
