Eberspacher DW5 water heater thermal cutout
Postby transitjon » Sun Jan 03, 2010 5:22 pm
hi is it possible to override the thermal cut out on the unit as mine will only run for about 10 seconds unless i keep the reset switch pressed in
thanks
jon
transitjon
Re: Eberspacher DW5 water heater thermal cutout
Postby Jim Archer » Sun Jan 03, 2010 5:44 pm
It's cos it's either the thermocouple gone, not catching properly due to fuel supply problems, or no water in it.
HTH
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby psv-hgv-flt » Sun Jan 03, 2010 5:49 pm
transitjon wrote:hi is it possible to override the thermal cut out on the unit as mine will only run for about 10 seconds unless i keep the reset switch pressed in
thanks
jon
that is not a good idea and is not solving the problem. sounds like it could be flame out sensor or lack of air intake.?? try looking hear. :wink:
http://eberspacher.com/downloads/techni ... manual.pdf
http://eberspacher.com/support-and-down ... ments.html
:wink:
psv-hgv-flt
Postby transitjon » Sun Jan 03, 2010 5:57 pm
Jim Archer wrote:It's cos it's either the thermocouple gone, not catching properly due to fuel supply problems, or no water in it.
HTH
Jim
it was all running fine until this morning neighbour knocked on door thought the van was on fire, there was alot of smoke coming out of the exhaust from the unit, it will know only run if i keep the safety switch pressed in, would that be teh thermocouple
transitjon
Postby transitjon » Sun Jan 03, 2010 5:59 pm
thanks
jon
:wink:
thanks for the links will check the air intake and flame sensor tomorrow
transitjon
Postby psv-hgv-flt » Sun Jan 03, 2010 6:49 pm
is it the dw5 or dw5s ??
psv-hgv-flt
Postby transitjon » Sun Jan 03, 2010 8:07 pm
i think it is just dw5
transitjon
Postby ake » Sun Jan 03, 2010 8:20 pm
If it is smoking then its probably the flame sensor causing it to shut down, something is wrong, like psv-hgv-flt says its probably a lack of air, when was it last serviced :?:
Postby transitjon » Sun Jan 03, 2010 8:29 pm
i did a mini service myself in september stripped it all down and cleaned it up, new plug etc, it has been working great till today
transitjon
Postby ake » Sun Jan 03, 2010 8:31 pm
Check that the air intake isn't iced(snowed) up
Postby transitjon » Sun Jan 03, 2010 10:42 pm
ake wrote:Check that the air intake isn't iced(snowed) up
air intake clear , when i turn on the unit it only stays on for 5 seconds and then cuts out what is the first thing to check
thanks
transitjon
Postby psv-hgv-flt » Sun Jan 03, 2010 10:54 pm
thanks
it takes more than 5sec for glowplug to fire her up. take plug out again and test out.
psv-hgv-flt
Postby transitjon » Sun Jan 03, 2010 11:06 pm
thanks
when i press the switch to turn on it whirrs for 5 seconds and then a there is a click on the control unit under the dash and it all stops. do you know the start up procedure so i can check each componet is it the blower or water pump first
transitjon
Postby psv-hgv-flt » Sun Jan 03, 2010 11:14 pm
whirrs could be water pump motor, pull pipe off and see if free. (by hand) ps what year is she and are we talking about hydronic..???
psv-hgv-flt
Postby transitjon » Sun Jan 03, 2010 11:24 pm
psv-hgv-flt wrote:whirrs could be water pump motor, pull pipe off and see if free. (by hand) ps what year is she and are we talking about hydronic..???
w reg swb ex bt it is the standard d5w not hydronic i have just found the start up procedure with timings so i think my fault is either
overheat ?
flame sensor short circuit
glow plug defective
burner motor defective
with all the smoke i had out of it this morning might be the burner motor, will try to check tomorrow thanks for your help
transitjon
