I tried araldite and i got about 20miles out of it, fair play if it works for you. I ended up buying a new one for £224 inc vat fitted it today but the thing still won't start, seems ever sinse i took the sensor out to inspect it after the last failed bodge.
Tried everything but it's having non of it. I can get it to run but only with the starter moter going and a can of easystart on constant but then cuts when you stop.
My last idea is to tow it with a landy.
I've totaly bled the system so theres definatly diesel at the injectors im starting to think the pump may be shot
Has any one else sufferd starting issues after changing the solenoid if so what was the problem?
2002 Ford transit swb 2.0 85 T280.
