MrMPuk wrote:I've never had much luck charging tools from my 1000w inverter for some reason and it wont run most kettles as they are well over 1000w.
angeleye wrote:think 4 awg is about 80 amps (American Wire Gauge) its there system of stranded wire carrying capacity incorporating several factors,have to make it complicated dont they,smaller the number the bigger loading it can carry
sidspop wrote:I believe you can get lower wattage kettles, or a camping stove is probably easier.
The charger thing could be down to the way the waveform is created.
Proper mains is sinusodal. I wont try to describe a sinusoidal waveform, easier for you to look it up. #inverters struggle to make a waveform that looks sinusoidal, so they generally produce pseudo sine wave. Looks like a bit of brick wall, that is stepped, and not smooth. It is ok for most things, but chargers nowadays are not the old fashioned tansformer type, they are switch-mode, and switch mode psus like sine waves.
Does any of that make sense, or have I confused everybody more lol
dirtydog wrote:angeleye wrote:think 4 awg is about 80 amps (American Wire Gauge) its there system of stranded wire carrying capacity incorporating several factors,have to make it complicated dont they,smaller the number the bigger loading it can carry
That's probably a bit heavy for what I need, will get the 8AWG. Anybody see any issues with that?
spospe wrote:If your inverter is rated at 1000 watts then at 12-volts this requires a current of 83 amps, so your cabling needs to be able to supply at least that current.
900-watt kettles are readily available from caravan dealers and these will run quite well off any type of inverter, both pure and modified sine wave.
Beware that if it takes 10 minutes to boil your kettle at a nominal 900 watts this will drain about 20 A/H out of your battery (the simple calculation shows 13.9 A/H, but at these high currents, you should allow for far more inefficiency, so about 20 sounds right).
