Mk3 Transit SVO Codes (special vehicle order) Help.
Postby Leeday » Thu May 20, 2010 10:33 pm
Hi, I have a Black Mk3 (F reg) 1989 Transit SWB with tailgate, 2 side loading doors, 2.0 Pinto with 4 speed auto box. In the drivers side footwell is a Ford Special Vehicle Order sticker which states:
Option -- Selection
7512 ------ 1
7515 ------ 1
7517 ------ 2
7527 ------ 1AAP
7529 ------ 4
7639 ------ 3
Does anyone know what these codes represent....1989 is a long time ago I know, but would be really interested to know what they mean.
Thanks in advance,
Lee.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Re: Mk3 Transit SVO Codes (special vehicle order) Help.
Postby AlanN » Fri May 21, 2010 8:55 pm
I never seen a list for the SVO specs, but it sounds like a Private ambulance
Infact, probably everything youve listed, I always thought they had 3 speed auto's
Postby AndyG » Sat May 22, 2010 12:43 am
7512 ------ 1Left hand battery suport
7515 ------ 1(Possible rear anti roll/stabilizer bar? Have a look!)
7517 ------ 2Twin heavy duty batteries
7527 ------ 1AAP (possible additional fuse panel)
7529 ------ 4 Battery cut off relay
7639 ------ 3 (Not a clue!)
Postby AlanN » Sat May 22, 2010 1:00 am
Where did get that list Andy...
Postby BROWNYS V6 » Sat May 22, 2010 7:47 am
one must be for the twin side loading doors :)
BROWNYS V6
Postby Leeday » Sat May 22, 2010 9:52 am
Hi Andyg,
Thanks for that,
The van definately has twin batteries (just replaced both trays), it has Split charge system with Ford labelled relay and wiring, will check for the rear anti roll / stabiliser bar and update later, havent noticed a additional fuse panel (did have all the dash out to sort out the wiring.....loads of accessories fitted and removed over the years by previous owners and wiring all over the place.......back to how it should be now), will look for battery cut off relay (definately handy to know if there is one.....don`t want to look silly and call Mr RAC out for a faulty relay :D ).
Hi AlanN... I thought it odd at first with the 4 speed auto, as the Haynes manual I happily purchased does not mention 4 speed auto or 3 speed auto with overdrive. It definately is a 4 speed auto (not overdrive) and it all looks original with no modifications been made, even down to the 4 foot tall auto gear select lever :D will clamber under the van and see if there are any serial / model numbers on the box to see if this sheds any light.
Thanks everyone for the comments, will update new info later...
Lee.
Leeday
Postby AlanN » Sat May 22, 2010 10:37 am
Interesting to know what all the SVO bit are, GUBB has a MK3 SVO too, not sure whats on his.
Post up some pictures when you get a chance :D
Postby AndyG » Sat May 22, 2010 6:51 pm
Update :arrow:
Andyg wrote:7512 ------ 1Left hand battery suport
7527 ------ 1AAP Special body colours
7639 ------ 3 Omit front passenger seat
:wink:
Brochure :)
Postby jezwild2001 » Tue May 25, 2010 5:54 pm
To keep this going, We have one at work, MK3 twin rear wheel long wheel base, Twin battery, Front and rear anti roll bar, power steering, Single side loading door, V6 efi 5 speed manual.
Codes are,
7502 2d
7514 1
7520 3
7584 4
7765 1
7786 1b
7512 2
7517 7
7526 12bcd
7616 7
7767 1
jezwild2001
Postby AndyG » Wed May 26, 2010 12:52 am
7502 2d
7514 1rear anti roll bar for lwb
7520 3
7584 4
7765 1fuel pipes for auxiliary heater
7786 1b
7512 2second battery support
7517 7twin batteries
7526 12bcdadditional fuse panel (6 fuses)
7616 7
7767 1
If I find the others, I'll update :wink:
Postby AlanN » Wed May 26, 2010 8:02 am
So, weve got this so far them Andy :wink:
7502 2d
7512 ------ 1 Left hand battery suport
7512 ------ 2 second battery support
7514 ------ 1 rear anti roll bar for lwb
7520 3
7526 12bcd ------ additional fuse panel (6 fuses)
7584 4
7616 7
7765 ------ 1 fuel pipes for auxiliary heater
7767 1
7786 1b
Postby AndyG » Thu May 27, 2010 12:00 am
7502 2dHSG-Auxiliary switches & instruments
7520 3Front fog lamps
7584 4
7616 7Increased GVM for UK police bus
7767 1
7786 1b
Postby Leeday » Thu May 27, 2010 8:42 pm
Hi Andyg,
RE: 7515 ------ 1(Possible rear anti roll/stabilizer bar? Have a look!)
I have crawled under van and there is definately no rear anti roll/stabilizer bar and no mounts or indications to suggest one was there and removed....
I will be playing with the van over the weekend and will see if I can find any other "extras" that it might be...
Thanks for the info so far :D
Lee.
Leeday
Postby AlanN » Tue Dec 14, 2010 12:56 am
Just got a MK3/4 quick ref catalogue and its got quite a few SVO illustrations, so I thought I would update some of Andy's entries in red, Ive got some images too, or if you have a SVO plate, I might be able to identify some of the numbers on a MK3 or 4
7502 2dHSG-Auxiliary switches & instruments T502 Accessory dash top pod
7512 ------ 1 Left hand battery sport
T514 ------ 2 rear anti roll bar for lwb (Slightly different to #1)
7515 ------ 1(Possible rear anti roll/stabilizer bar?)
7517 ------ 2Twin heavy duty batteries Twin battery cables
7520----- 3 Front fog lamps #3 is the U shaped surround for the lamp, #1 - 11 is a full fit inc. bumper, then there is switch 8A or 8B option
T535----- 12v accessory socket and loom
T541----- steel fuel tank
T549----- Filler neck guard
T560----- volt meter and loom
T563----- 1 Single seat with arm rest
T563----- 2 swivel seat base, with plastic shroud,
T563----- #36,37 door pads & pockets
7584 4
T595----- 1 additional fuse panel (8 fuses)
T603----- 1 180 degree rear door hinge
T607----- flashing beacon front n/s
T608----- flashing beacon front n/s & o/s
T613----- flashing beacon front n/s & rear o/s
7616 7 Increased GVM for UK police bus
T667----- 4 visor (some sort little sun visor)
T750----- 1 Executive seating
T750----- 2 Executive pads, panels, encapsulates, roof linings and carpets
T751----- 1 Executive seating
T751----- 2 Executive pads, panels, roof linings and carpets
7767 1
T777----- 1-6 rubber mouldings (bump strips MK3/4)
7786 1b
Postby AndyG » Tue Dec 14, 2010 1:46 am
8)
