help!!! 2.5 TD head?
Postby madmark » Mon Jan 30, 2006 7:39 pm
:lol: lets hope so mate i will keep my fingers crossed for you ,then you can pop round and do my oil leeks! :lol: ,sump gasket ,rear oil seal, alternator pump, power steering pump etc etc! :lol: :lol:
Postby TRANSITBILL » Tue Jan 31, 2006 1:13 am
:D Hooray hooray hes fixed his transit today..........good result then smiles all round best wishes B :D illy
TRANSITBILL
Postby 100ps_drw_hicube » Tue Jan 31, 2006 6:17 pm
TRANSITBILL wrote: :D Hooray hooray hes fixed his transit today..........good result then smiles all round best wishes B :D illy
thanks for the pm i flushed the rad thru several times but it didnt seem blocked :) still will be nice and clean now :)
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Tue Jan 31, 2006 6:20 pm
madmark wrote::lol: lets hope so mate i will keep my fingers crossed for you ,then you can pop round and do my oil leeks! :lol: ,sump gasket ,rear oil seal, alternator pump, power steering pump etc etc! :lol: :lol:
mark i have got a brand new sump gasket here, you can have it if you like. as i dont need it anymore my leak turn out to be rocker cover leaking and running down the sump :x if you want it pm me :)
100ps_drw_hicube
Transit Abuser!!
Postby MarkM » Tue Jan 31, 2006 9:19 pm
I see you seemed to have fixed your issues but I didn't see a result given for the hose pressure build up.
Although this is a later Transit, the header tanks are terrible for getting blocked on the attached picture I have indicated where you should look, running with the cap off and at basic temp there should be a steady stream of water coming through that pipe, if not then the thermostat is gunked up and more likely that pipe is blocked run a drill through it, not a screwdriver but a drill as the hole is too damned small and blocks if you look at it wrong.
I have tried all the ways I know of linking a picture on a forum and also doing it as a link but none want to work, are the image tags switched off somewhere?
MarkM
Postby 100ps_drw_hicube » Tue Jan 31, 2006 9:20 pm
cheers mate i had it running for a short while yesterday and got it up to temp the thermstat let go and water was coming thru the pipe you highlighted also before i redone the head it was pressurizing in seconds but now its hardly building up any pressure which i think is normal its seems to be the same amount of pressure of our other hi cube so it seems ok at the mo i think looking at the gasket that came of it was well knackered so that could of have been the cause :)
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Tue Jan 31, 2006 9:22 pm
Image :wink:
Postby MarkM » Tue Jan 31, 2006 9:23 pm
Thanks Luke...what was I doing wrong with the pic code?
MarkM
Postby Luke » Tue Jan 31, 2006 9:25 pm
MarkM wrote:Thanks Luke...what was I doing wrong with the pic code?
like this :D
[img]http://www.eclipse%20IGNORE%20THIS%20BIT%20AND%20THE%20SPACES%20watches.com/12264/cougars/web%20images/pressure.jpg[/img]
Postby MarkM » Tue Jan 31, 2006 9:28 pm
Thats what I did except for the % sign....BB forums add silly bits like that, I am a Mod on a BB based forum and an Admin on another so I know my way around the codes maybe my browser was reading it funny
I just cut and pasted your version into my original post and still it doesn't show.....GRRR! Oh well next time.
MarkM
Postby MrMPuk » Tue Jan 31, 2006 9:32 pm
% is just a space, but if you put spaces in coding they wont work!
Postby MarkM » Tue Jan 31, 2006 9:37 pm
MrMPuk wrote:% is just a space, but if you put spaces in coding they wont work!
Ah then this is a very old version of BB then as the later versions allow you to put spaces and then it codes them to suit the forum.
Quick test then using%20 in place of the space and it looks like it works :lol:
My other interests are far from Transits and I use my webspace a lot for images for one thing or another.
Things like this...
MarkM
Postby MrMPuk » Tue Jan 31, 2006 9:39 pm
This forum is running the most upto date version which is phpBB 2.0.19!
Postby MarkM » Tue Jan 31, 2006 9:47 pm
Sorry my mistake I am used to VBullitin not BB which takes care of the code irregularitys, plus the navigation is a lot simpler, like for example you can go to the last page, rather than the NEXT link you have with this....I found this when I was looking at the picture I copied and then trying to get back to my post to edit it. Never mind now I know I will just have to adjust my speed when editting pics...asumming I have to add anymore.
Oh btw threadjack over, thanks for tuning in :wink:
MarkM
Postby 100ps_drw_hicube » Wed Feb 01, 2006 6:57 pm
all fixed but have got to do the valve clearances now :x they were fine to start with but now have a very rough idling :x have also got to check the belt out as it seemed very slack :? its not long been fitted so it should be ok
100ps_drw_hicube
Transit Abuser!!
