We need axle info!!!
Re: We need axle info!!!
Postby Mfr » Sun Aug 04, 2013 1:16 pm
What do you guys think about this? http://www.ashcroft-transmissions.co.uk ... oductId=70 A possible upgrade for the Salisbury type G axle? Here is a picture of my spare 5.14
First impression is that the spline count is very different but I take it it wouldn't be hard to fit a matching mount for the prop? The bolt count for the ring matches @10.
I've also been looking at these guys... http://www.justdifferentials.com/Produc ... 44-411T-NG Thats the dana 44 I'm not sure they fit, they do have a 26 spline count and 10 bolt pattern. The ring size is 223mm which is close as makes no difference 8.8" so maybe this is a better match http://www.justdifferentials.com/Produc ... 8.8-411-EG
Thoughts gents?
Mfr
Postby Tango330 » Tue Oct 29, 2013 9:52 am
I fitted an exchange transfer box from Ashcoft Transmissions to my Land rover 5 or 6 years ago. Really good service and it's still working. I have also just bought an exchange gearbox from them for the same truck. Excellent service again.
On the other hand, I'm off to Transaxle Services in Halifax for a new diff for my Mk 7 RWD on Thursday. New diff fitted with all the seals bearings etc., for slightly more than Ashcrofts want for just the CW & P.
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby paulaspantry11 » Sun Dec 08, 2013 1:12 am
what axle will fit a mk3 transit 2.5 di
paulaspantry11
Postby DougT » Thu Apr 03, 2014 4:58 pm
Twin Axle CWP
Some time ago, KenB fitted a Mk6 CWP into a Mk1/Mk2 twin wheel axle. He used a Mk6 flange as the Mk1/Mk2 pinion has a smaller diameter spline. This was redrilled and tapped to take the Mk1/Mk2 prop joint.
I'm doing the same thing as the Mk6 CWPs are easier to find.
For info, I have found that the Mk4/Mk5 flange will also fit on the Mk6 pinion spline. Not sure about Mk3 but I would think that it is a good bet to be the same as the later pinion.
Cheers
Doug
DougT
Postby Leeday » Fri Jan 09, 2015 9:14 pm
[quote="nokites"]Transit 1995 (08/1994-07/2000)
Axle Type
34 Timken (less L.S.D)
51A Heavy Salisbury (less L.S.D)
53 Heavy Salisbury (less L.S.D)
34 Timken (with L.S.D)
51A Heavy Salisbury (with L.S.D)
53 Heavy Salisbury (with L.S.D)
[quote]
Hi,
Do any of these types relate to the ATLAS axle, or is that a different code altogether?
Cheers.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby Greg L. » Fri Jan 16, 2015 4:10 pm
I have a Salisubry (twin) axle with a 5.38 diff and a Timken axle with a 4.11 diff. Is there any (simple) way to switch the diffs between the two axles ?
Greg L.
Postby driggers » Thu Apr 09, 2015 8:36 am
I have a Mk6 transit twin wheel with a noisy diff, i know someone with a Mk5 diff, will the diff fit in the Mk6 axle?
driggers
Postby MinorMatt » Tue Sep 15, 2015 2:26 pm
I believe all six stud axles (up to, and possibly beyond) utilise the same spline count (33) and shaft diameters
Postby norfolkandgood » Mon Feb 29, 2016 7:47 pm
I have seen mk7 twin wheel axle with disc brakes fitted in mk6.
Don't think there were any issues but I can ask the gadgie when I see him next
norfolkandgood
Postby bj928 » Sun Apr 16, 2017 1:01 pm
been looking around for options, and as the mk8 transit is now sold in America, they do after market gear ratio options and lsd, they only list for mk8, but i would has at a guess our mk7 is the same dana axle as mk8 as far as crown wheel and pinion goes,
crown wheel and pinions from 3.08 ratio
https://www.yukongear.com/partslist.aspx?SearchMode=Cat&CatID=35&CatName=Ring%20&%20Pinion%20Gear%20Sets&MakeID=2&MakeName=Ford&ModelID=613&ModelName=Transit%20Van%20150&Side=Rear&DriveType=RWD&DiffID=322&DiffName=Ford%209.75%22%20(9%203/4%20inch),%20%2711%20&%20up
and lsd for transit dana
https://www.yukongear.com/productdetails.aspx?ProdID=11591
bj928
Postby Transitpartsuk » Tue Aug 15, 2017 4:51 pm
We ordered MK8 crown wheel and pinions in as well as the bearing kits and they are nearly twice the size as the MK7 ones.
Aftermarket ones not available at the moment (from what I can see) But they will be at some point in the near future
MK7 and MK8 Axles are different. They had the same chassis when they changed to Euro 5 in 2011, so everything chassis wise is the same. After 2014, axle is different etc.
Transitpartsuk
Registered Trader
Registered Trader
Postby bj928 » Tue Aug 15, 2017 5:03 pm
thats interesting, will have to do more research
bj928
Postby Transitpartsuk » Tue Aug 15, 2017 9:10 pm
If you need any info Let me know. Can tell you all the axle ratios with part numbers for most things.
Transitpartsuk
Registered Trader
Registered Trader
Postby bj928 » Tue Aug 15, 2017 9:26 pm
i'm planning a mustang irs on my mk6, and my mk2, so not much use to me, but thats, just out of interest, is a mk6 axle about 66 inches face to face width wise
bj928
Postby RayTrans » Mon Oct 16, 2017 3:19 pm
Hi all at Ford Transit Forum,I need yere help as I am going to buy a Mk7 3500 Rwd axle in the next few days from a scrappy and I was wondering if there is a way of telling the difference between a Semi floating and a Fully floating axle. My van has a total towing weight of 6000 kg so I am thinking that my axle is a fully floating axle, as I do not want to buy a semi floating axle and be left with it. Thanks
Cheers 8) 8)
Ray
MK6 Transit High Roof RWD 115 Bhp Twin Sliding doors.
RayTrans
