bj928 wrote:been looking around for options, and as the mk8 transit is now sold in America, they do after market gear ratio options and lsd, they only list for mk8, but i would has at a guess our mk7 is the same dana axle as mk8 as far as crown wheel and pinion goes,
crown wheel and pinions from 3.08 ratio
https://www.yukongear.com/partslist.aspx?SearchMode=Cat&CatID=35&CatName=Ring%20&%20Pinion%20Gear%20Sets&MakeID=2&MakeName=Ford&ModelID=613&ModelName=Transit%20Van%20150&Side=Rear&DriveType=RWD&DiffID=322&DiffName=Ford%209.75%22%20(9%203/4%20inch),%20%2711%20&%20up
and lsd for transit dana
https://www.yukongear.com/productdetails.aspx?ProdID=11591
Gunslinger wrote:mk3's are definitely the same orientation as a mk2.
as for the mk4 one you have there, if it came from a chassis cab (single or twin wheel it makes no difference) then things arent the same, one of those things is that the shocks are sometimes mounted backwards like you said, but as 100ps says not always, i have actually seen a chassis cab with the mountings for both orientations on the vehicle![]()
.... Friday after throw together vehicle anyone![]()
.... you can almost picture one rolling of the production line at 5 to 5 on a friday night, one shock mounted one way and the other side mounted the opposite way !!
Luke wrote:Rolo's idea - look here for origanal post!!!!
We need to compile a usefull information thread on rear axles - what fits what and whats on what!!!![]()
I think it will take more than 1 person to do this so add as much info in this here in this thread and i will sort it all out to one post!!![]()
make sure you use the mk or the year so we know what were talking about!! look here to find which mk is which!!!!and also state if its SWB or LWB single or twin your talking about!!!!
so basically post any info you have on rear axles here
