We need axle info!!!
Re: We need axle info!!!
Postby james66 » Wed Jan 29, 2020 11:12 pm
I have a mk7 axle in my mk6 I can take pics & as many measurements as you need if it helps?
The mk7 is a Dana 248, the 248 is nigh on a d60
james66
Postby bj928 » Thu Jan 30, 2020 1:09 am
i need measurements of the crown wheel, and u can't give me that without taking the axle apart
bj928
Postby loot » Thu Jan 30, 2020 8:16 pm
I have a dana mk7 crown and pinion if you need measurements?
Ids map here
loot
Postby bj928 » Thu Jan 30, 2020 8:32 pm
loot wrote:I have a dana mk7 crown and pinion if you need measurements?
some photos and some dimensions would be good, bolt spacing, and i'll see if i can find a dana in america that is the same
bj928
Postby loot » Thu Jan 30, 2020 8:46 pm
Ok it's in work and I'll see what I can see if I remember tomorrow :wink:
Ids map here
loot
Postby loot » Fri Jan 31, 2020 11:07 am
It isn't scientific but close enough I think.
I have a couple more pictures of you need them
Ids map here
loot
Postby bj928 » Fri Jan 31, 2020 11:39 am
not having much luck matching up the sizes, the crown wheel size is the same as Dana 44, but the axle casing of the american dana 44 doesn't look like a transit mk7 dana axle, its almost like ford made or had their own axles made to take dana internals, will keep looking
bj928
Postby bj928 » Sun Feb 02, 2020 10:20 am
ok, so last night a went to see a transit friend of mine, i believe he is on here somewhere, and we measured a mk8 axle with the same wheels on as my mk6 van, so a like for like comparison, and it turned out the the mk8 axle is no more than 2 inches wider than a mk6, so should just about fit under the arch with the right wheels, great news for faster transits as the mk8 axle has LSD option, and lots of ratio option
bj928
Postby ossie cossie » Fri Mar 27, 2020 3:07 pm
I have a 2004 twin rear wheel axled transit crew cab pickup, can some one tell me what the diameter of the axle tube is close to the leaf spring saddle, i have an air bag kit to go on and need to fab up some brackets to go over the round axle tube with flat plate on top.
thanks
tony.
ossie cossie
Postby ossie cossie » Fri Mar 27, 2020 3:11 pm
this is the type of axle, i need the diameter near the anti roll bar bracket.
ossie cossie
Postby Airthies » Fri Mar 27, 2020 5:57 pm
It's a Dana 60 full floating axle should be able to Google the info if you can't measure your own?
Or at least get a close guestimate.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby jckm2000 » Tue Dec 22, 2020 5:07 pm
Question:
Do twin wheel axels, front & rear, fit single wheel chassis's?
I have a MK2 single wheel motorhome and I want to change to twin, 15"
Cheers, Jon
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby Keef » Tue Dec 22, 2020 10:22 pm
The obvious axles to use would be MK3 but even the twin wheeler only had 14" wheels .
You're going to struggle to get the later independent front suspension hubs to fit your beam axle but if you managed it, you could go upto 16" if you redrilled Mk6/7/ 8 wheels.
It would steal a fair bit of your payload too!
Transit Custom use 15" single wheels which might fit MK2 if you use larger wheel nuts but you won't know for sure without trying one. The are cheap enough on eBay.
Keef
Postby Airthies » Wed Dec 23, 2020 5:56 pm
It may be neat between the arches for fitting your twin wheels across the centre.
Why do you want to change from single to twin?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby jckm2000 » Thu Dec 24, 2020 3:40 pm
Well, I want to fill those rear wheel arches with rubber, don't like the rear wheels set so far in, and I'd like uprated springs etc to raise the ride height on this MK2 motorhome. 2.0 litre Pinto.
We plan to do a long travel to parts of the world where the roads are little better than rocky tracks (You only have to go as far as Greece in fact!). Would like some AT tyres on there too.
Pic:
http://www.kloudnine.co.uk/transit/1.jpg
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
