sh4rp3 wrote:Cheers chaps I really appreciate the advice and will keep you posted on results
If you change your filter get the original from fords.
taz666 wrote:don't run before you walk, the wiring IS the most common cause of this code and others on fwd transits, I know as ive fixed hundreds of them even after other garages have fitted new pumps, p1665 is a communication code for the pump, if the wiring is touching the starter, the loom shorts out and the engine stops, simples!!
redwoodss wrote: I know this was some time ago, but can anyone please point me to instruction to access the wire loom that may be touching the starter. I think taz666 post was on the button.
redwoodss wrote:Thanks,
I believe they were Mondeo engines
redwoodss wrote:Oh, so my problem is unlikely to be the wiring then?
Any other ideas. It used to start spot on, ran out of diesel or someone nicked the diesel, filled up and problem since. Cracked the jets and all ok. Tried with Bradex easy start and it will turn over but not without bradex. The it has p1665 error, glowing light flashing, and IDS says earth issue, hence I thought Wiring
Users browsing this forum: Micktransitman
