disconnect egr
Re: disconnect egr
Postby AndyG » Mon May 25, 2009 11:54 am
MattBlackMinibus wrote:Sorry to drag up this old subject,
but I've been meaning to do this for ages,
and need to clarify...
If I blank the vacuum pipe with a ball bearing (so it looks std)
and remove the butterfly,
will that do the job?
Thannks
YES :!:
But it will make the engine induction noisier :!:
Re: disconnect egr
Postby MattBlackMinibus » Mon May 25, 2009 12:24 pm
Andyg wrote:YES :!:
Sweet :lol:
Cheers Andy
Last edited by MattBlackMinibus on Mon May 25, 2009 4:50 pm, edited 1 time in total.
Starting All Over Again
MattBlackMinibus
Re: disconnect egr
Postby Marauder » Mon May 25, 2009 12:45 pm
This morning having read all this i went out to my 1999 tranny and i pulled the rod off from the pump end, cabled tied it to the alloy inlet tubes so if i need to refit it i can just push the end of rod back on,, then i put a small cable tie round the other little pulley thing keeping the butterfly valve open,took it up the rode for a few miles it seems better, over the next week or 2 i will see if it alters the fuel consumption or performance......Now all i have to do is the same to my TD5 Discovery. :D
Ford Transit 280 SWB,,Year 2008,,2.2,, If it can,t be fixed/repaired/ with a 4 pound lump hammer then it must be an electrical problem.
Marauder
Re: disconnect egr
Postby AndyG » Mon May 25, 2009 12:55 pm
If you want more power, then you'll have to follow this
:arrow: viewtopic.php?f=18&t=3968
