2.9 V6 transit (SVO Police-spec?) gearbox mounting and other
Postby madvanman » Thu Feb 09, 2006 3:10 pm
here is a pic of the adapter plate fitted to a transit 2.9
its about 3/4" thick.
madvanman
Customised!!
Postby madmark » Thu Feb 09, 2006 3:24 pm
luke i am shure the plate used on the transit mt75 to v6 looks alot thicker ! :? also at the moement i think there is a 1.9inj ambulace on ebay! :)
Postby Luke » Fri Feb 10, 2006 10:11 pm
madvanman wrote:looks like a spacer/adaptor for the starter motor
so what starter motor do they use :?: come to think of it what about the flywheel and clutch are they one offs :?:
Postby 24vMk2 » Fri Feb 10, 2006 11:49 pm
Looking at where the adapter plate bolts to the V6, looks the same size as the cars bellhousing, I would be tempted to use the 2.9 XR4x4 flywheel and starter.
I found out, the clutch on the XR4x4 is the same size as the Di's, in fact I know of one 24v powered car using a turbo diesel's clutch
24vMk2
Postby Luke » Sat Feb 11, 2006 11:55 am
24vMk2 wrote: in fact I know of one 24v powered car using a turbo diesel's clutch
a turbo diesel Di's clutch?
Postby madmark » Sat Feb 11, 2006 12:13 pm
i think alot of clutch plates are the same , 241mm i am useing a pinto 1.6 clutch in the 3ltr essex this turned out to be the same as the svo 3ltr clutch! :)
Postby 24vMk2 » Sat Feb 11, 2006 2:02 pm
Luke wrote:a turbo diesel Di's clutch?
Yup, I'm also fairly sure the MT's drive plate fits the T9 'box, because I'm sure he told me he is using it in a Mk2 Escort! :shock:
24vMk2
Re: 2.9 V6 transit (SVO Police-spec?) gearbox mounting and o
Postby terry steward » Sun Dec 23, 2012 3:00 pm
Hi guys,I Have a 2.9 V6 L reg i think mk iv Transit Minibus,,Its like an Extra long Wheelbase,As it was i think a 15 Seater,,it Belonged to the Sultan of Brunei,As i tapped in the Reg L999WEL !!,and several Fords came up,Mindeos and Transits with the WEL Letters,,,any way,,I need a Gearbox i think,,as it Screams in all but 4th and Reverse,,its a 5 speed box,,Seems Very low geared,it also Seems as if some sort of EGR has been Disconnected,as there are things under there that Arent hooked up,and it runs a bit odd at times,i think because its been tampered with,but i cant seem to contact the two Subsequent owners,,the other thing i need,is a 16 inch spare wheel,With 225 Tyres on
terry steward
Postby Luke » Sun Dec 23, 2012 3:02 pm
a normal transit diesel MT75 will fit - the only difference is the ratios inside :D
Postby MinorMatt » Sun Dec 23, 2012 3:53 pm
Are you sure its 16" wheels Terry - they were not fitted to transits of that age!
The standard ones were 6J x 15" with 6 wheel studs and 225/70/15c tyres
Postby robbie.cee » Tue Jan 01, 2013 7:49 pm
fordboynick is selling those adaptor plates- or was - try him! :wink:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby captain hook » Tue Jan 01, 2013 11:37 pm
robbie.cee wrote:fordboynick is selling those adaptor plates- or was - try him! :wink:
Rob.....This post is over 7 years old :shock: Bonehead :? :lol: :lol: :lol:
captain hook
Postby robbie.cee » Wed Jan 02, 2013 11:37 am
Haha. Was a resurrected thread then LOL was in active topics!
I'll wake up in bit!
Had
MAKE IT FIT
robbie.cee
Postby layalog » Wed Jan 02, 2013 5:25 pm
pssst who goes thier :|
its not leaking, its just another tear
layalog
Postby robbie.cee » Wed Jan 02, 2013 6:29 pm
layalog wrote:pssst who goes thier :|
:lol: you know!
Had
MAKE IT FIT
robbie.cee
