Back wheel squeal driving me mad
Re: Back wheel squeal driving me mad
Postby Birmingham » Thu Mar 01, 2018 8:50 pm
bigjohnthomas wrote:Take the caliper off and move it in and out and put some love juce on it
Bloody annoying squeeeeek that :x
Worst thing I’ve ever heard. Goes right through you
Birmingham
Postby Punto443 » Thu Mar 01, 2018 8:54 pm
Birmingham wrote:
Punto443 wrote:Mine was doing this and it was the handbrake lever on the rear caliper sticking
just a bit of lube ?
I freed it off a couple off times, but long term it needs striped down and seals changed. £8 for seals and an hours work :)
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Birmingham » Fri Mar 02, 2018 10:21 am
Would a new calliper be easier to do ?
Birmingham
Postby Punto443 » Fri Mar 02, 2018 10:35 am
Easier yeah, but £60-70 and Still 1/2 hours work :lol:
Depends how much money you have?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby TallPaul » Sat Mar 03, 2018 5:55 pm
I had some pattern rear pads in my Custom and the friction material started delaminating from them, I'd get an irritating squeal once they'd warmed up. Does it go when the brakes/handbrake are applied? Take the pads out and check them.
TallPaul
Postby Birmingham » Wed Mar 07, 2018 2:32 pm
TallPaul wrote:I had some pattern rear pads in my Custom and the friction material started delaminating from them, I'd get an irritating squeal once they'd warmed up. Does it go when the brakes/handbrake are applied? Take the pads out and check them.
Yeah it does mate. When I turn the steering wheel slightly left and right too, like a rubbing metal on metal squeal.
Birmingham
Postby Birmingham » Wed Mar 07, 2018 2:33 pm
Did a pad change cure the problem ? Thanks for replying
Birmingham
Postby 547 HEW » Wed Aug 20, 2025 7:09 pm
Had this approximately 20,000 miles after new Motorcraft discs and pads were fitted about 3 years ago. Noticed it first in hot dry conditions.
It could be silenced by the application of handbrake.
Inspected pads. The nearside inner pad was stuck fast in the caliper. There was a build up of rust on the lower land of the caliper, causing this.
I removed this, and fitted new pads and spring clips. All rear pads now move very easily.
The squeal has gone
Hope this helps
547
547 HEW
Postby knobby1 » Wed Aug 20, 2025 8:09 pm
547 HEW wrote:Had this approximately 20,000 miles after new Motorcraft discs and pads were fitted about 3 years ago. Noticed it first in hot dry conditions.
The squeal has gone
Hope this helps
547
Thread is well over 7 years old....the people you're replying to haven't been on here for years.
But thanks for the info..!
