2012 2.2fwd Euro5 Problems please help
Re: 2012 2.2fwd Euro5 Problems please help
Postby Callum aspinall » Mon Jun 15, 2020 9:15 pm
But now there’s a bit of a problem On full throttle through all the gears it runs perfect but when your in traffic and keeping the Rev range low say 1500 to 3000 rpm plodding along at 30-40 the van runs very lumpy and jerky and starts to smoke really bad and smells of unburnt diesel until again you use full throttle then it clears
So basically if I thrash it with my foot to the floor it’s fine until I have to drive at a normal speed then it starts
Has anyone come across this of have any suggestions
Callum aspinall
Postby karl » Tue Jun 16, 2020 10:35 pm
Callum aspinall wrote:But now there’s a bit of a problem On full throttle through all the gears it runs perfect but when your in traffic and keeping the Rev range low say 1500 to 3000 rpm plodding along at 30-40 the van runs very lumpy and jerky and starts to smoke really bad and smells of unburnt diesel until again you use full throttle then it clears
get the counter resets done in special functions this may help the smoking issue
karl
Tranny Lover!!!
Postby Robbieback369 » Wed May 17, 2023 4:30 pm
Did you end up solving the issue please as mine has the same problems stuttering in low revs and same codes Including low fuel pressure and airflow meter etc
Robbieback369
Postby knobby1 » Sun May 28, 2023 7:58 pm
Robbieback369 wrote:Did you end up solving the issue please as mine has the same problems stuttering in low revs and same codes Including low fuel pressure and airflow meter etc
He hasn't been back since June 16 2020....so we'll probably never know.
You may be better off starting a new thread with your issue as it may get lost in this one.
