Help Identifying Part - Ford Transit Custom 2015 2.0 Ecoblue
Re: Help Identifying Part - Ford Transit Custom 2015 2.0 Eco
Postby Goldline1200 » Fri Jan 19, 2024 4:49 pm
I took the van to the garage this morning. They agreed the leak looked like it was coming from the fuel inspection cover but also wanted to check everything else just in case. They swapped the fuel insection cover and were satisfied this was the only fix to make. I drove home and I've checked on the van throughout the day and so far, no oil drips. Phew!
Thank you all for your help in resolving this.
Goldline1200
Postby Goldline1200 » Mon Jan 22, 2024 10:59 am
Thank you all. This oil leak has been fixed. It was indeed the fuel pump inspection cover. The existing one's seal had perished and come loose. The replacement was fitted (without the need for any belts to be removed) and I was on my way in 30 minutes. If it wasn't for the help I got here, the job could have been longer and more expensive.
Goldline1200
Postby knobby1 » Mon Jan 22, 2024 7:47 pm
Goldline1200 wrote:Thank you all. This oil leak has been fixed. It was indeed the fuel pump inspection cover. The existing one's seal had perished and come loose. The replacement was fitted (without the need for any belts to be removed) and I was on my way in 30 minutes. If it wasn't for the help I got here, the job could have been longer and more expensive.
Thanks for the follow up/feed back...we appreciate it as many don't even bother to come back.
