Bad starting
Re: Bad starting
Postby Mike16 » Thu Jan 16, 2025 6:14 pm
Well done...That's close to normal pressure, ish...it should be 230bar +/-10%...or 3336psi +/-10% at idle. Cranking pressure, (before actual starting), is slightly higher at ~300bar or ~4350psi.
I suggest doing a rund on the learns, can't hurt and may even help.
Lord Knobrot[/quote]
I'm not sure what you mean?[/quote]
What our metalworker says...
Learns are basically a "re-calibration" of the fuel system....In the service functions tab in Forscan.
Thanks, i'm just waiting on the cable, should be here tomorrow then i can mither you to death :lol:
Mike16
Re: Bad starting
Postby Mike16 » Thu May 01, 2025 7:14 pm
So an update. Finally got around to a starter draw test. It was pulling 180 amps apparently, way over what it should have been and robbing modules of required power. Fitted a new starter today, hey presto new van that starts immediately hot or cold. Thanks to all for your suggestions and help. :D :D
Mike16
Re: Bad starting
Postby metalworker0 » Thu May 01, 2025 7:18 pm
How may amps should it be pulling (average on say a 10c day) ..just so i know, should someone else have the same problem.
Re: Bad starting
Postby Mike16 » Thu May 01, 2025 10:10 pm
metalworker0 wrote:How may amps should it be pulling (average on say a 10c day) ..just so i know, should someone else have the same problem.
70 to 80 i think the mechanic said.
Mike16
Re: Bad starting
Postby metalworker0 » Thu May 01, 2025 10:28 pm
thanks
