Fuel leak fix
Re: Fuel leak fix
Postby knobby1 » Tue May 20, 2025 8:36 pm
ranso73 wrote:So I cleaned up the area and noticed that there was some PTFE looking tape on the engine. In the photo it’s on the right hand. Then I ran the engine and think that fuel is coming out of that part too.
So what’s it called and can it be replaced by a trainee novice?
Thanks.
The teflon plumbers tape is actually on the "left" injector feed pipe connection in your photo.....might be ok on plumbing fittings but not a good idea on Diesels running upwards of 1600bar (23,200psi) of fuel pressure, if any of that tape finds it's way to the injector internals...it can cause all sorts of dramas.
That fitting is actually part of the injector assembly...
http://www.catcar.info/ford/?lang=en&l= ... gzNjcrMTMz
