Radiofence wrote:If the damage is where the loose intake pipe plugs in...mines broken too. Big chunk missing. I guess where someone has forced the pipe in and flexed something
Nondisclosed wrote:Progress report
- cleaned intercooler
- replaced damaged hose from intercooler to engine
- inspected hose from air box to turbo ( no visible damage)
Took it out for a spin, might just been in my head hit seemed to have more pull in the lower gears. Got to about 55mph and the dreaded chimes of death and lights came up. Plugged it in, and turbo sensor A saying stuck open again.
Restarted the van, came up almost straight away, drove a short distance and it's not come back up but I know it will as soon as I drive more than 100 metresWhere do I start now? Still revs but lots of loss of power
knobby1 wrote:Nondisclosed wrote:Progress report
Have you actually replaced the turbo vane actuator..?? I read your comments but no mention of it being replaced.
Nondisclosed wrote:What are the chances that this unit is dud? Just trying to gather as much info before I order another. If for example this unit isn't the fault, Where's the next step? When I say I tested the motor, it was direct to the motor contacts.
knobby1 wrote:Nondisclosed wrote:What are the chances that this unit is dud? Just trying to gather as much info before I order another. If for example this unit isn't the fault, Where's the next step? When I say I tested the motor, it was direct to the motor contacts.
If the actuator motor and little plastic gears are working ok, maybe the vanes in the turbo itself a sticking, not unheard of.
Radiofence wrote:That doesn't look like a genuine hella inside. Wot markings are on it.
