Mk7 2.4 CUTTING OUT!
Re: Mk7 2.4 CUTTING OUT!
Postby Tomdye1 » Tue Jun 03, 2025 11:01 am
A bit strange...TDCi pumps aren't timed....they're essentially "plug 'n play"..
Lord Knobrot[/quote]
I am unsure then!
I have ordered a new SCV from the link above and hopefully this will solve the issue!
Thank you for your help on this, I will put un update in here once its fitted and hopefully all will be sorted! (unfortunately not holding out much hope as it has been nothing but trouble!)
Tomdye1
Postby MinorMatt » Tue Jun 03, 2025 11:49 am
Symptoms are consistent with those experienced on my 2.4 euro 4. But I had no codes
Changing the SCV sorted it.
Postby Tomdye1 » Tue Jun 03, 2025 12:18 pm
MinorMatt wrote:Symptoms are consistent with those experienced on my 2.4 euro 4. But I had no codes
Fingers crossed then! Thanks Matt
Tomdye1
Postby knobby1 » Tue Jun 03, 2025 7:57 pm
Tomdye1 wrote:Fingers crossed then! Thanks Matt
Make sure you do the learns or it will probably run like a pig.
Postby DanMK7uk » Wed Jun 04, 2025 9:07 pm
Reset PRV open duration counters
fuel pump learn
Injector pilot learn
DanMK7uk
