metalworker0 wrote:i had a feeling the temp sensor was within that heater unit that why i said buy one of those heaters ..
TESTING - it may be this way --- i'm not certain
first you need the wiring digram to work out the colours of the wires
nowa days temperature sensors work in a peculiar way. they are called K-TYPE THERMOCOUPLES
from wiki
A Type K temperature sensor, also known as a thermocouple, works based on the Seebeck effect, which creates a voltage when two different metals are connected and exposed to a temperature difference. In a Type K thermocouple, the metals are Chromel (nickel-chromium alloy) and Alumel (nickel-aluminum alloy). When these metals are joined, and one junction is exposed to a temperature gradient (a temperature difference), a voltage is generated, proportional to the temperature difference. This voltage can be measured and correlated to the temperature using standard calibration tables or electronic devices.
ive delved into this before
so answers .. my own from a while back
First check continuity between the two wires of the thermocouple. If you have continuity it's probably fine. Usually they are either good or bad, but in rare cases they can be compromised by corrosion or something. To check if it's accurate you'll need a voltage meter than can read millivolts. Put the leads on each wire of the thermocouple. At 32*F the voltage across them will be zero. As temp increases the voltage goes up. 70*F will be .843 and 1000*F will be 22.251. I'll attach one of the standard voltage/temp charts for type K.
chart
https://www.ford-trucks.com/forums/atta ... download=1
chart is mind boggling --- like a bus time table for the whole of a county....im sure a simplified one can be found
so basically your BCM knows what these voltages are for given temperatures .. and it does the maths
the thermocouple may be available for a couple of pounds on ebay
AND first though ... as with all of these mind numbing electronic faults, see first answer about disconnecting battery for 15 mins, and making sure all your electrical system .. battery voltage , earths are up to scratch
metalworker0 wrote:will look for 1 hour tonight to see if i can get some sort of video
you've not plugged forscan into it to read the code, have you?
the manufacturers part number off the heater would go a long way to me delving and finding out things
metalworker0 wrote:https://www.youtube.com/watch?v=ZwmF-c6TZpQ&t=571s
posted wrong link
Frag wrote:If you have no fault codes present but it’s still counting down to no start,you may have actually fixed the fault,but the no-start inducement will not clear until the PCM / REDCM see a ‘clear pass’ of the system operating.
This usually involves a specific sequence,each different depending what triggered the initial countdown.
(Slow and fast heal faults)
Some also involve a very specific drive cycle,if your running out of miles before ‘no start’ it won’t cut out,but may not restart if stopped (turn stop start off anyway if fitted)
Another app (in FDRS anyway) allows you to clear a 0 miles / no start,and gives around another 30 miles reset to let you drive and clear the fault inducement.
Frag wrote:Regardless of voltages,if there is a fault on the tank temp sensor circuit,you should have a DTC for it.
If you cleared all codes and then did a roadtest,it would either log a dtc for if there’s a problem you’ve not fixed,or come out of inducement.
It’s not just a case of driving for 30 miles though.
It’s a very specific warm up,idle,drive at 2000 rpm,and then like 70kmh in 5/6 gear for 15 mins (IF it’s an efficiency fault that is)
FDRS,when reading DTCs,it then shows any slow or fast heal faults so you can see what’s causing inducement.
These can also be seen in datalogger.
But again,there are multiple FDRS apps to clear each cause of inducement,so whether it was a boost / turbo fault,EGR fault, efficiency fault,or MAF fault,the drive cycle is different…..
