2012 minibus won’t start
Re: 2012 minibus won’t start
Postby Bobbybalboa » Sat Sep 19, 2026 4:17 am
Frag wrote:Make sure the inertia fuel cut off behind glove box hasn’t been tripped……
This I have not come across before during all my research for the problem.
Do you have more specific details of how I check this and reset it. I have forscan but I am very new to it as I've always had VAG cars/vans and been using VAGCOM.
[*]2012 Transit Minibus 2.2 tdci RWD
Bobbybalboa
Postby Bobbybalboa » Sat Sep 19, 2026 4:47 am
Above are the fault codes after the ecu clone
Bobbybalboa
Postby Frag » Sat Sep 19, 2026 3:13 pm
Open the glovebox and fold it down / out
There’s a switch bolted to bottom of A pillar,above strut top.
Usually has a yellow rubber cap,push it down in the centre,it will click if it was ‘activated’
You may have to clear the dtc after
That info is for a RHD,if your in Norway I assume LHD so don’t know if the switch behind glovebox or on drivers side if LHD ?
Frag
Ford Technician
Users browsing this forum: Baidu [Spider]
