Di fuel pump (belt failier)
Postby bortaf » Tue Nov 29, 2005 7:41 pm
Right got it all back togther, and guess what :?:
it won't start, Bugger :lol:
Checked the timing untold times and it' spot on, thing is i can turn the engine over using the (seized) fan, should i be able to or have i cracked a piston/bent a valve, there is compression cause you can feel it building up as you trun it but a mech i spoke to earlyer reckons there no way i should be able to turn the engine buy hand and to be honist i've never tried before :(
any ideas chaps, failing that anyone got a di going cheep :lol:
no not doing a bird impression :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MrMPuk » Tue Nov 29, 2005 7:46 pm
Yeah you can turn the engine quite easly.
Postby Nighthawk » Tue Nov 29, 2005 8:07 pm
I'm baffled by this.......whats the engine doing now?
I've done hundreds of snapped belts on Di's over the last ** years and haven't had one not run after.
How did you do the tappets after you built it back up......please tell me you didn't use the old skool rule of 9 :?
Nighthawk
Postby bortaf » Tue Nov 29, 2005 9:43 pm
How do you set a Di then mate? :D
I've changed heads ect but allways kept the rods in a bit of card to keep em in order so never had to find out how to do it to know it was different (if you follow) :)
Never known it either but then most people i spoke to were also surprised i managed to snap both cetre posts on the rocker shaft with out actually bending the shaft itself :lol:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Nighthawk » Tue Nov 29, 2005 10:08 pm
The correct way to adjust the clearences on the 2.5 Di is
Open valves completely--------------------------Adjust valves
1 and 6......................................................... 4 and 7
2 and 3 .........................................................5 and 8
4 and 7 .........................................................1 and 6
5 and 8 .........................................................2 and 3
The clearences are 0.20mm (inlet) and 0.40mm (exhaust), thats about 8 and 15 thou in old money :lol:
Doing the old 1 down adjust 8 thing gets the clearences all wrong because of the cam angles.
Nighthawk
Postby bortaf » Tue Nov 29, 2005 11:58 pm
cheers mate :D
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
