transit 2.9 conversion
Postby 24vMk2 » Sun Dec 11, 2005 9:28 pm
madmark wrote:what about getting a gearbox place to swap the 2 boxes around if its poss and use the bellhouseing from the granada and the transit caseing??? :?
This is the fun bit, the transit's bellhousing won't fit the V6, its to big, and the gear lever comes out the top of the 'box. this part of the casing is all in-one.
On the granada 'box, it uses a remote linkage, and puts the gear lever to far back. the bellhousing also us one casting, and theres no way of fitting the transit gear lever on it.
Been round the scrapyard today, looking at this problem, got myself a pinto to MT adapter plate, once redrilled, it will work! :)
24vMk2
Postby Luke » Sun Dec 11, 2005 9:38 pm
24vMk2 wrote:Been round the scrapyard today, looking at this problem, got myself a pinto to MT adapter plate, once redrilled, it will work! :)
any chance of so piccs, etc. while your doing it! - i think a few including me :P would be interested in this!!! :D
Postby 24vMk2 » Sun Dec 11, 2005 9:58 pm
Yup, no problem, was going to anyway :P
24vMk2
Postby carcrazysi » Mon Dec 12, 2005 6:06 pm
they did actually do a 24v cossie granny manual, but only for police.
ITS ON A NEED TO KNOW BASIS
carcrazysi
Postby bortaf » Tue Dec 13, 2005 12:05 am
Ex police cars are where the manual MT boxes usually come from but they are bleeding rare :D
I know you can get a RWD box for a car made from a 4x4 box and a 2wd tail end, the only transit 24v i've seen in the flesh was auto :(
you can shorten the remote selector on an MT75 but not enought to keep the origional stick position but you might get it far enough forward to clear the hand brake?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MRspivvy » Thu Jan 05, 2006 5:17 pm
The gearbox you need can be found in late mk3 ambulances. my old one was a 1992 2.9efi, with 5spd manual MT75. even has the gearstick in the right place. hard to find, this engine/box in a transit was special order only.
MRspivvy
Postby madvanman » Fri Jan 06, 2006 2:22 am
MRspivvy wrote:The gearbox you need can be found in late mk3 ambulances. my old one was a 1992 2.9efi, with 5spd manual MT75. even has the gearstick in the right place. hard to find, this engine/box in a transit was special order only.
Or ex-police riot vans, mine is a 2.9efi + 5 speed manual mt75
madvanman
Customised!!
Postby madvanman » Wed Jan 11, 2006 7:08 pm
:idea: Does anybody know if you can transfer the innards from a 4X4 MT75 into a transit MT75 casing? so you get the correct gearing and gearlever position?
madvanman
Customised!!
Postby MrMPuk » Wed Jan 11, 2006 10:56 pm
I suspect you probably can as mine is running the inards from the 2WD escort cosworth.
Postby Luke » Wed Jan 11, 2006 11:03 pm
MrMPuk wrote:I suspect you probably can as mine is running the inards from the 2WD escort cosworth.
didn't know they ever did a 2wd escort cossy :?
Postby 24vMk2 » Wed Jan 11, 2006 11:43 pm
They never did.
There was a 2wd Sierra Cosworth, that used a Borg-Warner T5 box.
The Escott used a MT75 4x4, same as the sierra 4x4
24vMk2
