Removing a stripped torx bolt
Re: Removing a stripped torx bolt
Postby Ucof » Sat May 17, 2008 8:41 pm
I tried drilling the nut out...and the drill ran out of batteries :roll:
The hole for the bit was a little larger however, so I put the H6 bit in and gave it a big hit with a hammer.
Then tried unscrewing the nut, only for te now hammered in bit to turn in the nut, stripping the head more :(
I think I'll wait for the battery to be recharged, and I just drill the f*cker out. :(
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Postby rabbit » Sat May 17, 2008 8:46 pm
Sounds like taking the p**s to me.
STANDARD SUCKS. MODIFY IT ?
rabbit
Postby Ucof » Sat May 17, 2008 8:49 pm
Well, it is either taking the p*ss, or just trying to torment me into giving up.
It will not win! :D
Ucof
Powered by Nutella
Postby AlanN » Sat May 17, 2008 9:03 pm
You cant buy Gelignite over the counter can you!
Postby magpie » Sat May 17, 2008 10:14 pm
I thank you "Nutella" fer the post you have managed to frighten the brown stuff outa me as I intend to do mine this week & they all look pretty ropy,any problems may try just pouring JENOLITE around the runners in the hope it soaks under them.
magpie.
magpie
Postby Ucof » Sat May 17, 2008 10:23 pm
You are most welcome! :D
I'll post a picture of the tool I have used to loosen up the really tight ones :)
Ucof
Powered by Nutella
Postby neo1 » Sun May 18, 2008 9:43 am
I got my rounded one out with the aid of the next size up spline bit hammered it in and it was stubburn but it came, spline bits tend to bite in quite well in this situation ive found.
neo1
Postby Ucof » Sun May 18, 2008 10:46 am
Here's what I was using yesterday as I have not many proper tools for the job, and had to Macguyver something together:
(please forgive the lino pattern, it's only a temporary cover for our dining room table :) )
These are the individual tools, the bit, the bit connector and adjustable spanner.
This is how it all goes together (surprisingly):
However, now the battery for the drill is charged up, I'm going outside to drill the b*stard out. :)
Ucof
Powered by Nutella
Postby Ucof » Sun May 18, 2008 12:03 pm
BAH!
Having drilled through the bolt, and hammered the end of it off, im now left with a hole in a bolt in a hole in the van.
There's no head at all now other than a round one, and I don't have a square peg to put in it.
The bolt seems to rotate slightly now when I move the sliding rails, but there is under an inch of movement before the floor ridges block it.
I'm giving up on it now. :(
Ucof
Powered by Nutella
Postby MrMPuk » Sun May 18, 2008 12:15 pm
Drill the head off with a bigger drill bit, but don't go all the way through.
Postby thrud » Sun May 18, 2008 12:19 pm
Mk 6, 90 T350, soon to be the right shade of blue 'RAL 5015'
thrud
Postby Ucof » Sun May 18, 2008 1:55 pm
MrMPuk - Can I have my J back please? :D Thanks for fixing it :)
Thrud - Thanks for finding those for me -there's a Screw fix outlet near us actually, however, I could had £6.99 to spare, I'd get it :(
I'll be smacking the s*d with a hammer and chisel shortly. Hopefully, I'll be returning with good news :)
Ucof
Powered by Nutella
Postby MrMPuk » Sun May 18, 2008 1:57 pm
Just do what I said above!
Postby Paul 1 » Sun May 18, 2008 3:26 pm
You want to buy yourself a proper socket set and a box of torx heads, adjustable spanners are a sure fire way of rounding nuts off.
Personally Id drill it as Mr Puk sudgests, if it were in a differnt place id sudgest heating it with a proper gas torch but with all the flamable stuff in the cab it wouldnt be my first choice.
54 plate 260 MK6 SWB Exec pack 85 ps soon to be reemapped. Dead locks and arma plates on rear.
Paul 1
Postby Luke » Sun May 18, 2008 5:31 pm
just chisel the fu***r off :lol: and before you say you dont have a chisel use a screwdriver :lol: and if you dont have a hammer use a house brick :wink: :lol:
