cossy tranny wrote:hi there i have a v reg td van [hopefully to be 24v cossy soon] i converted ths to a tdengine had problems with the pats system on the pump so put a manual pump on and got the boost turned up van does 95 all day long and is quick through the gears have run lie this no prob last 4 year
cossy tranny wrote:all that needs done is the actuator rod altered this lets the turbo hold more boost before the waistgate on the turbo opens .my turbo is turned up as much as it wood go or so i was told by the tuning place who turned it up
crazyscoot wrote:My actuator has the actuator wound most of the way out ie adjustment nut towards the back of van. Be good to hear that ive got it the wrong way as i'm in for a bit treat if it is![]()
My turbo pipes are sound and secure and never had the problem you have.......although i may be running low boost!
ryzman wrote:crazyscoot wrote:My actuator has the actuator wound most of the way out ie adjustment nut towards the back of van. Be good to hear that ive got it the wrong way as i'm in for a bit treat if it is![]()
on your turbo it should have a long threaded shaft from the diaphragm! what you do is shorten the rod as to shorten the spring inside the diaphragm then as the turbo boosts the small pipe that is on the compresion side of the turbo cant push the actuator as far open there for keeping more boost presure in the inlet system and there you go more pulling power hope this helps
