LPG conversion kits
Postby bortaf » Wed Jan 25, 2006 12:30 am
http://www.lpg-kits.com/index.htm
seem a good site with plenty of options :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby stevew » Wed Jan 25, 2006 2:45 am
24vMk2 wrote:
stevew wrote: If you've got a camper you can plumb in your cooker/fridge to run from LPG and it works out cheaper.
S
No, you can't do that,
Fridges use the gas as a gas, taken from the top of the bottle, the engine uses it as a liquid, which it then heated before being sucked into the engine.
That's true but I'm sure you can get tanks with both outlets. Although I can't find any now so maybe I imagined it! :lol:
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby vannut » Thu Jan 26, 2006 12:27 am
As far as I know it's illegal to have a tank in your car with outlets for the cooker and the engine from the same tank.
In response to the initial question, I've run several vehicles over the last 10 years with LPG and never had any problems. I currently have a Range Rover 4.6 which was converted with the basic system a few years ago. I'm just updating it to gas injection at the mo.
The later gas injection systems are much better as you don't lose any power, in fact I had a 3 lite Vauxhall Omega and a 4 litre Discovery both converted in early 2002 and stipulated that there mustn't be any reduction in power. In the end they were both tuned so that they were actually faster on LPG :lol:
I'm no longer in 'possession' of these two vehicles now but as far as I know they are still with the 'company' and still going strong. (They WILL have been well thrashed!)
Where's me anorak!!!
vannut
Postby madvanman » Mon Jan 30, 2006 2:59 am
Steve
You will probably find that those duel outlet tanks were for the american market as a lot of winibagos have lpg conversions running from the same tank as the cooker.
in the uk it gets complicated if you use the tank for a cooker as well as running your engine, as you can legally part fill your tank from the large orange bottles but proving how much you have used as fuel and how much is for cooking is difficult.
madvanman
Customised!!
Postby stevew » Mon Jan 30, 2006 12:14 pm
Hmmm, interesting.
I was wondering about that. I have an Eberspacher diesel heater in my van (if I can ever fix it!) which I would have thought I could run legally from red diesel or even heating oil. Since it doesn't have a sperate tank I can't easily do it, or can I :?:
Steve
stevew
Postby vannut » Mon Jan 30, 2006 12:16 pm
You could run it on red diesel but you'd have to have a separate tank. If customs and excise catch you with the old cherryade in your main tank you lose your van! For the amount of fuel it uses I would just feed it from your main tank. :wink:
vannut
Postby stevew » Mon Jan 30, 2006 12:20 pm
Yep, the risk is far bigger than the gain. Like I say it still doesn't work so not really an issueanyway. At this rate I'll probably have it running just intime for summer! :lol:
Steve
stevew
Postby Basil Brush » Wed Feb 01, 2006 4:09 pm
Watch out buying second hand kits, a lot of people have been taking them of gas forklifts and passing them off as car kits and they just not suitable for the job.
Also the tanks are supposed to be tested every ten years, so if you buy second hand check the tank manufacyure date.
I have fitted several kits but only the vapouriser kind not the injection set up on lap top ones.
Basil
Basil Brush
Postby Luke » Sat Feb 11, 2006 10:01 pm
has anyone mounted a tank under a van :?: if so what size :?: i have only ever seen them inside the van :!: and are all LPG tanks cylinders :?: or can you get square ones :?
:D
Postby 24vMk2 » Sat Feb 11, 2006 11:16 pm
Luke wrote:has anyone mounted a tank under a van :?: if so what size :?: i have only ever seen them inside the van :!: and are all LPG tanks cylinders :?: or can you get square ones :?
:D
I have seen vans with the tanks mounted on the outside, but there is a legal limit, i belive it's 300mm from the lowest point on the tank to the ground. Very few vans can do that :(
Never seen square tanks, probably because corners are weak, you can get 'doughnut' shaped tanks tho
24vMk2
Postby jay » Sat Feb 11, 2006 11:29 pm
i got lpg on my jag its a 3.6 straight 6 auto..does about 22mpg on gas and about the same on petrol with a tank behind the original petrol tank which is behind the rear sets the lpg tank is oval in shape...fitted the kit myself with no problems....havent fitted one to a transit yet..but have fitted a kit to a ldv chassis cab and i fittted the tank onto the side of the chassis behind a set of metal side skirts for safety.the ldv does about 25 mpg.
mk1 connect tourneo
jay
