transit swb turbo conversion
Postby 100ps_drw_hicube » Wed Feb 01, 2006 10:29 pm
no crap on the brighton bypass i can get a 100mph if the hills were a little longer i can just get 105mph
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Wed Feb 01, 2006 10:32 pm
Luke wrote:
ryzman wrote:well how come with my 4.56.1 diff foot through the floor max revs down a megs hill i can only get 90mph
100ps has bigger dia tyres on his!! :D
do you think that 1 inch can make that amount of difference :?
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Wed Feb 01, 2006 10:34 pm
whats the size of your tyres i.e. ***/**x** :?:
100ps_drw_hicube wrote:no crap on the brighton bypass i can get a 100mph if the hills were a little longer i can just get 105mph
:lol: ever wonder why your engines dont last too well :lol: :twisted: :lol:
Postby 100ps_drw_hicube » Wed Feb 01, 2006 10:45 pm
my tyres are 185 r15 8 ply and the speed rating is r ye my engine doesnt seem to have a limiter it keeps going to 4300rpm :lol: the only limiter is the floor :lol: thats why they dont last :!: on my old hi cube i seized it somehow by going down the mway flat out for about 4 hrs :D still at least it was a bannana engine easy to get hold of another :)
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Wed Feb 01, 2006 10:54 pm
well according to my QUICK calculations - and i may be wrong cos i could do with the aspect ratio of the tyres but with a 5.16 diff @100 mph you should be doing 7000 rpm ish - so mabe your speedo's out!! :?
what rpm is it doing at those speeds :?:
Postby stevew » Thu Feb 02, 2006 3:47 am
Nah your out a bit there! :shock:
My van with a 5.14:1 diff does 62.5mph (100kph) at 3000rpm. Scaling that up gives 100mph at 4800rpm.
I've had mine up to about 80 and a bit approaching 4000 rpm but bottles it! The engine realy screams.
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby MrMPuk » Thu Feb 02, 2006 5:39 am
2 of my old works vans used to regularly get up to 95 on the clocks, but with the GPS in the van I found out this was only 80!
Postby 100ps_drw_hicube » Thu Feb 02, 2006 12:54 pm
Luke wrote:what rpm is it doing at those speeds :?:
it is doing about 4300rpm maybe a tad more tbh i am concentrating on the road more :D but i have been followed by someone on a cb400 and he said his clocks were up to a ton and mine were reading just over :? so i dont think the speedo can be that far out maybe 5mph :?:
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Thu Feb 02, 2006 1:33 pm
Hmmm yeah seems i'm out abit :oops: :lol:
i worked it out from the tyre back did seem a bit high i'd guess ive chose the wrong aspect ratio for the tyre what tyres have you got steve?
and also are all 5th gears the same ratio?
Postby 100ps_drw_hicube » Thu Feb 02, 2006 2:36 pm
aspect ratio?? that must be what the other 2 numbers are that are on the tyres mine is 102/103?? if that makes any sense?
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Thu Feb 02, 2006 4:04 pm
maybe you have a 4.63 diff! :? my rac van has 5.14 in 5th it seems to get revy at 60mph! :? so mine will be about the same as steves! i am running 225/70/15 on the rear! :)
Postby 100ps_drw_hicube » Thu Feb 02, 2006 4:09 pm
might have but the tag by the back cover says 5.14 :? :? but arnt most turbos limited to 4000rpm as my dads seems to cut out when you hit the top of the revs :? also his is very revvy at 60mph theres definately something different about mine :? :?
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Thu Feb 02, 2006 6:25 pm
100ps_drw_hicube wrote:aspect ratio?? that must be what the other 2 numbers are that are on the tyres mine is 102/103?? if that makes any sense?
mabe they are the Li the load the tyre can take
some commercial tyres dont have the aspect ratio on its the 225/THISBITx15 :D
Postby Luke » Thu Feb 02, 2006 6:32 pm
OK try again madmarks van with 225/70x15 a 5.14:1 diff and an MT75 with 0.82:1 5th gear :D
736 x 5.14 x 0.82 / 60 x 100 = 5107 revs per min @100 mph
same van with a 4.63 diff
736 x 4.63 x 0.82 / 60 x 100 = 4657 revs per min @100 mph
:? think thats right!! :lol:
Re: transit swb turbo conversion
Postby Luke » Thu Feb 02, 2006 6:34 pm
BTW anyone know the answer to the origanal question :?:
ryzman wrote:The question i would like answered is what has the 4.1-1 ratio rear diff ?
:lol:
