jolly olly wrote:Just copied and pasted this from the other site hope it makes sence to some one, so if your brave enough to try it let us know the out come.
The quote.
I would use any of the two 2-T oils, whichever I would get cheaper.
You can also use the Mobil Extra 2T.
Important is, that those 2T-oils should comply with JASCO "FC" or ISO L-E "GC" or "GD", which should be written on the bottle. All 2T-oils as per these norms burn with an ash content of less than 0,05%.
toniel wrote:Is anyone out there using 2 stroke oil and acetone?
Altransit wrote:toniel wrote:Is anyone out there using 2 stroke oil and acetone?
Yes, I am. Very good results so far
cabbage wrote: What ratios are you using? And how long have you been using them together?
Altransit wrote:cabbage wrote: What ratios are you using? And how long have you been using them together?
300ml of 2 stroke, 30ml acetone, per 60 litres of diesel fuel
I've been using it for a couple of months, but not continuously
