petrol leak
Postby FredTransit » Thu Mar 23, 2006 7:04 pm
Wolfie wrote:did some checking and some crawling under the van got none of the funnel things.
it is a van tank fred, is also supposed to have a vented cap but it was too cold and dark to check last night, so that is my job tonight.
Our panel van and minibus both have after market locking petrol caps, and they don't seem to have vents in them.
FredTransit
Mk2 Trannyist
Postby Wolfie » Thu Mar 23, 2006 7:42 pm
neither does mine.
totally confused now. :D :D
handbook says nothing about cap, haynes says vented cap, workshop manual says nothing about cap. yet i have a two month old cap which is leaking from between the seal and filler neck. :? :?
1979 2L pinto camper
Wolfie
Postby Luke » Thu Mar 23, 2006 10:45 pm
i think on my mk1 pickup the vent is a pipe about 3/8" that runs inside the filler neck!!! :? and im pritty sure the pipe then goes into the top of the sender unit :? from memory :?
i'd go have a look but its no longer on my drive!!! :(
Postby Wolfie » Thu Mar 23, 2006 10:48 pm
same as what i have luke, do you have a vented cap or not???
Wolfie
Postby Luke » Thu Mar 23, 2006 10:51 pm
Wolfie wrote:same as what i have luke, do you have a vented cap or not???
not sure but i suppose it must be vented or the pipe would be no use :?
the pipe does finish inside the filler neck doesnt it? im trying to picture it :)
Postby Wolfie » Thu Mar 23, 2006 10:53 pm
yes about inch and half inside,
Wolfie
Postby Luke » Thu Mar 23, 2006 11:04 pm
Wolfie wrote:yes about inch and half inside,
must be a vented cap then :)
im stuck with this one :? sorry i cant be any help :oops:
