vibration on steering wheel
Postby Nighthawk » Sat Apr 22, 2006 9:05 pm
replacing the discs on a current shape transit is a different job to that of the older shapes.
The current vehicle needs the front wheel bearings to be removed with the hub and disc in order to remove the disc.
It's not the disc retaining bolts that people have trouble with, it's getting the bearing assembly out of it's carrier thats difficult.
Transit.........Job done
Nighthawk
Postby MrMPuk » Sat Apr 22, 2006 9:06 pm
Not really to much of a problem though as the van is a smiley!
Postby 100ps_drw_hicube » Sat Apr 22, 2006 9:15 pm
baconsdozen wrote:Incidentally over the years I've still found nothing to beat the original Plus-Gas as a releasing fluid,always interested in other peoples opinions on alternatives.
best stuff i found was similar to wd40 but was made by repsol worked a treat cheaper than wd too but no where sells it :(
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sat Apr 22, 2006 9:20 pm
must admit i have a can of plus-gas for really stubborn jobs it's the best one ive come across - wd40's not the best it just sells well cos its like biro, hoover and ................ transit!!! :wink: :lol:
front discs
Postby paj » Mon Apr 24, 2006 7:38 pm
didnt have time to check discs over weekend,setting off to work this morning and found i have lost some pressure on the braking system so i thought maybe a leak,checked all round no leaks anywhere, just had front wheels off and found the problem, the vented part of the disc on drivers side has corroded causing movement in either side of disc. couple of questions ..should i change bearings regardless..why the loss of pressure?
paj
Postby Nighthawk » Mon Apr 24, 2006 9:55 pm
you mean the vent ribs have corroded to the extent of breaking away? :shock:
Thats a dangerous situation to be in
Your braking pressure loss could have been for a couple of reasons, if the disc's strength has been reduced you might actually be compressing the 2 faces together and gaining a longer pedal travel. Or the distortion could be pushing the pads away from the disc and your having to push them back out.
Old transits had a decent wheel bearing set up, re grease them and put them back :D
Nighthawk
Postby crazyscoot » Mon Apr 24, 2006 10:12 pm
I always thought wd40 is a thin lubricating oil? were as plus gas is a penetrating oil. Plus gas also has a chemical reaction with rust which helps with removal.
Negative reality inversion
crazyscoot
Postby MrMPuk » Mon Apr 24, 2006 10:17 pm
WD in WD40 means water displacement.
Postby paj » Mon Apr 24, 2006 11:11 pm
better get them replaced sharpish,was going to risk it until weekend when i had more time
paj
Postby stevew » Tue Apr 25, 2006 1:40 pm
Plus Gas rules! :P
Seriously it's the best stuff I've used, never fails to amase me what it can shift! :shock:
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
