Gunslinger wrote:wiring is relatively simple if you work through things logically
So glad you said that GS, co eletrics are a complete mystery to me!
tractive-effort wrote:One other thing, I was told that the temp gauges should stay static (like the fuel gauge does) relative to the temperature of the engine when switched off.
tractive-effort wrote:Doesn't seem to be a mis-read of Haynes - probably more a misprint IN Haynes....
Anyway, I've been driving it around without the thermostat in now for about 4 days and the needle will sit just above the white block at the bottom of the gauge. Intermittently it will move to about half way over, sit there for a minute or so and then return to just above the white square. The heater blows VERY tepid air out, even with the gauge at halfway, so the engine is not getting too warm. I have fitted a new temp gauge tonight (I got it NOS cheap) and will be picking a new sender unit up tomorrow. I will also put a new thermostat in too for good measure, though for the summer I will probably just omit it..
PS: It has not used any water
