SIX YEAR ANTI COROSION WARANTY ?
Postby AndyG » Fri May 05, 2006 10:46 pm
100ps_drw_hicube wrote:
oldhenry wrote:Or of course buy a VW next time :D . 12 years bodywork , but you won't need it 8)
ye youll just need a shed full of spare engines :lol: :lol: :lol: :lol: :lol:
Yeah :!: But at least I know who to come to, to give us a hand :lol: :lol: :lol: :lol:
Postby motorwise » Fri May 05, 2006 10:47 pm
Andyg wrote:
motorwise wrote:change of ownership isn't a problem because the antiperforation warranty is transferable - the problem is proving it isn't stone damage or accident damage - but I've seen more than enough (and I'm sure everyone else on here has as well) transit mark fives bursting out all over the front arches to know they're not all caused by damage - I would try pushing a bit harder but dealers will always play the "it's had accident damage" card - try ford customer services see if they'll help - can't help you with the phone number it's been about 16 years since I work for a ford main dealer
good luck with it
It's through them, I've been dealing with :roll: :lol: :lol: :lol:
I also offered them to carry out a localised repair so that they didn't have to change the whole door aperture (up to the roof and B pillar inc.) :roll: and as I've compromised my side, I was hoping that they would do likewise :roll: NOT :!:
at one time they used to bend over backwards - how times change :(
http://www.motorwise.net
motorwise
Postby 100ps_drw_hicube » Fri May 05, 2006 10:49 pm
not me then :lol: :lol: :lol: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Fri May 05, 2006 10:53 pm
I know they'd rather I buy a new one :roll: And having waited patiently for their mk6 auto to become available, I have to say I was very disapointed with it's durashit gearbox :!:
Hence I went back to a mk5 :!:
Postby 100ps_drw_hicube » Fri May 05, 2006 10:56 pm
have you ever tried a mk5 with auto clutch?? :lol:
100ps_drw_hicube
Transit Abuser!!
Postby motorwise » Fri May 05, 2006 10:59 pm
I suppose now it's nearly two models back they're not interested - bad form
motorwise
Postby AndyG » Fri May 05, 2006 11:02 pm
100ps_drw_hicube wrote:have you ever tried a mk5 with auto clutch?? :lol:
Yeah :!: As a matter of fact I did :!:
76PS engine (so that's Lucass out of the equation) Works like the mk6 auto but you stir the cogs yourself which has an advantage in so far as you change when you want :D
Clutch judder evident :( and would still roll on hills/makes parking in small spaces difficult. :(
Postby AndyG » Fri May 05, 2006 11:05 pm
motorwise wrote:I suppose now it's nearly two models back they're not interested - bad form
They should have kept the mk5 going like they have in China then :D Shouldn't they :?: :lol: :lol: :lol: :lol: :lol:
Postby Gunslinger » Sat May 06, 2006 11:37 am
good luck with your chasing of this but i think you'll just hit the same brickwall, there is only a couple of ways i know to stop this rot, and that is either waxoyl, or expanding foam, both of these have to be done fairly early though, one works by eradicating water and moisture and stopping it attacking the metal my effectively coating it in oil whereas the principle behind the other is to fill the area completely, stick like sh*t to a blanket and remove moisture as it cures .... leaving no where for air, thus no condensation or water.
once they have rotted in this area, my advice is chop it all out, but redesign the mounting along the edge so that you dont have a "twin skinned" section ..... they did not have problems with front wheel arches rotting until they redesigned this area, only problems on earlier front wings were where the door post ran close and and the gap could get blocked with crap causing the same "twin skinned" affect
Gunslinger
Postby AndyG » Sat May 06, 2006 6:58 pm
Gunslinger wrote:good luck with your chasing of this but i think you'll just hit the same brickwall, there is only a couple of ways i know to stop this rot, and that is either waxoyl, or expanding foam, both of these have to be done fairly early though, one works by eradicating water and moisture and stopping it attacking the metal my effectively coating it in oil whereas the principle behind the other is to fill the area completely, stick like sh*t to a blanket and remove moisture as it cures .... leaving no where for air, thus no condensation or water.
Waxoyl :roll:
When I first bought the van this was the first area treated :!: took the front mudguards off, shuved the flexi hose right up the hole revealed by the mudguard removed, and gave it a good spray (obviously I couldn't see up there)
so either I didn't do a good job or the rust was already there :(
Remember I had a '96 van and therefore knew where the weakspots were
Expanding Foam :!: :?: :?:
Elseware (when discussing sound deadening insulation in difficult to reach/awkward areas(cables in the way etc...))It was noted that this stuff helps rot your steal as it absorbes and retains moisture, can shrink etc...so this was out of the question :!: Please give any further views on this foamy stuff :wink: Is there a particular type/brand to use/avoid :?:
Postby madmark » Sat May 06, 2006 7:40 pm
:? i think alot or rust is allready there in the metal! its very strange how most or nearly all smiley now have rust ,they can be star treck miles or low miles and pamperd :shock: but they all have it! its such a shame such a great van and easy to keep and maintain! :cry:
Postby oldhenry » Sat May 06, 2006 8:37 pm
Posted: Fri May 05, 2006 9:04 pm Post subject:
oldhenry wrote:
Or of course buy a VW next time . 12 years bodywork , but you won't need it
Ah, :) but engines are cheaper than bodies 8) and a sight easier to fit! :D ( form experience) :evil:
Hey , VW T5 engines are guaranteed 100K now
Believe nothing you hear and only half you see
oldhenry
Postby AndyG » Sat May 06, 2006 8:52 pm
madmark wrote::? i think alot or rust is allready there in the metal! its very strange how most or nearly all smiley now have rust ,they can be star treck miles or low miles and pamperd :shock: but they all have it! its such a shame such a great van and easy to keep and maintain! :cry:
I agree with you there :D That's another reason why Ford should carry out the repairs regardless :!: and at least honer their waranty :!: of a miserly six years :!: when others are happy to offer at least double that :shock:
Postby AndyG » Sat May 06, 2006 9:00 pm
oldhenry wrote:Hey , VW T5 engines are guaranteed 100K now
But they could also use excuses not to pay out as well :shock: like; you went 1 mile over your recomended service schedule sir, or You carry too much weight all the time, or you shouldn't run your air con continuesly. :lol: :lol: Who knows what they'll find :( :( :lol: :lol:
Postby tractive-effort » Sat May 06, 2006 10:29 pm
The regular pressure-washing/steam-cleaning EVERYWHERE is the only REAL rust preventor....along with a bit of Dinitrol or Red Oxide perhaps (sees Waxoyl off!!)
tractive-effort
Users browsing this forum: trevorhp
