by APH » Mon Dec 28, 2009 9:35 pm
When you say the relay is ok, did you unplug it to test it, or do you mean it clicks when pressed?
If it clicks, it dosent neccessarily mean the contacts "make", try unplugging the horn connector, and test across the wires with a voltmeter, if when the horn button is pressed you get 12V, then the horn itself is faulty, if not, then could still be relay, or bad earth (one of the two wires on the horn goes to earth (chasis) its on a lug screwed to the bulkhead behind the engine fusebox.
03 2.4 TDDI 90 t350 LWB HR white panel vanX reg 2.4 TDDI 90 t350 MWB MR Yellow Panel van56 reg lwb high roof connect, 1.8 tdci 90 t 220(\__/)
(")_(")
this is bunny
